August 29, 2026, 01:11:15 pm
Hoffman Amps Forum image Author Topic: Question about the Hoffman 1 channel AB763  (Read 4373 times)
Offline coreysan
« on: April 02, 2015, 05:38:32 pm »
I'm working on a AB763 for the Fender Super Reverb kit, and also comparing it to the Hoffman AB763 one and two channel
designs (which are really really nice, I might add!).
So far the one thing I don't understand is that on the Hoffman schematic, the
preamp signal going to the PI has a 47k resistor (r30) going to ground.
What does that do?
Re: Question about the Hoffman 1 channel AB763
« Reply #1 on: April 02, 2015, 07:11:48 pm »
It simulates the loading of the AB763 Intensity pot.
Hoffman's AB763 is not a true AB763. It uses an earlier version bias modulating tremolo. Look at the schematics to compare.
« Reply #2 on: April 03, 2015, 07:36:12 pm »
What Sluckey said
If you look at the original AB763 there is a 50kra intentsity pot connected to that same point and the bottom end of the pot is connected to ground
I am replacing the 50kra post with a 47k resistor
Offline coreysan
« Reply #3 on: April 06, 2015, 03:29:56 pm »
Ah yes - makes perfect sense. If I had read through the entire schematic...
I'm sorry!
