September 16, 2026, 12:06:12 am
Hoffman Amps Forum image Author Topic: 5E3 build log! Criticism and suggestions welcome!!  (Read 23712 times)
Offline Champ_49
Re: 5E3 build log! Criticism and suggestions welcome!!
« Reply #50 on: April 21, 2015, 08:08:15 am »
Hey Slucky.   Yeah I think I was really over doing this one.
I managed to finally get the right bolt, nut and plastic washer. It tooke a couple of trips back and forth to the local store. I got two nuts and realized only after I came back that one didn't  fit the bolts I got Even though it was the same size. Weird. So I went back and  actually had to test out the same batch of nuts that were in the bin to get one that fIt. Weird.
All in all the amp sounds great!
I just ended up setting up a grounding scheme keeping in mind to keep the power and signal grounds separate.  That's what I did and there seems to be a lot less hum than before.
I just wanted to make sure my amp build has no more hum so what do you guys think? Did I do this right According to what I am observing?  When I plug the guitar in there is a noticeable humming more like 60 cycle.  On some pickup combinations its almost very quiet.  But yes I do get the hum when I plug something in. But when I unplug it it is dead silent.  Even when turning the volume alp the way up I only hear some faint white noise. As far as that prognosis goes I'm assuming my grounding is ok.
Thanks for all the help!  And taking the time to check out this Log.
I will post pics later
Offline Champ_49
« Reply #51 on: April 21, 2015, 08:29:10 am »
Hey,
It is perfectly OK to ground the speaker ground to the chassis star ground bolt.
If you look at Doug Hoffmans layout and follow this method it works perfectly. I have built 3 Tweed Deluxe amps and all came out perfect. I did add another 1 meg pot to my Tweeds so I can adjust both sides of the V1, hi/lo and mix them with a pair of 220K resistors. In other words the 3 pot Tweed Deluxe volume tone works out kind of strange to me. Sounds good but limited. 2 volume and 2 tone pots works very well for these amps.
Most of the time hum is caused by the heater wires and the V1 tube picking up the 60hz AC hum and amplifying the signal. You could have the wires twisted out of phase from V1 to V2. Unplug it and check with a meter and make sure all of the heater wires are in phase. Pin 9 V1 must also be pin 9 V2 etc. Pin 4-5 must be pin 4-5 both V1 and V2. If one gets out of phase it can induce hum.
Center tap on the heater wire coming from the tranny must be on star ground. Very tightly also and get good contact to the chassis for all grounds. Also the heater wires have to be twisted carefully and very tightly so the hum is cancelled out.  Its all in a careful wiring layout and make sure you have space between all the wires coming from the board to the tubes or anywhere in the wiring scheme. I use a stiff wire so it is bent to stay in place away from other wires etc.
I do not really like the soldering wires to the pots method. I make up a solid wire ground buss and solder grounds to the buss wire and suspend it rigidly and attach the grounds starting at the inputs and work right to left in a flow. Even though I used the 12A Switchcraft jacks which do ground to the chassis at the input this is totally quiet and the ground loop has no effect as far as noise.
I have also built up 5 Marshall 2204 builds successfully which are much more finicky that the Tweed Deluxe builds. These are very hum sensitive.
I also have found after building near 20 amps that Mallory Caps have better tone than the Orange Drops. I have used Mallory, Sprague, Sozo, and about to try out the Mojo Dijons.
Anyway you need to solve the hum problem and I have been there and try out checking the heater wires and their twist and location and distance from other wires and phasing and see if that solves you hum issue. You could also have a bad preamp tube, haha.This happens a lot.
Good luck
Thanks DCbluez.  Thanks for the great advice,  Actually the 5E3 has  hardly any hum now that I rewired the grounds and separated the signal and power grounds.  I don't know why the original layout on Triode showed a buss connecting the signal cap to the power cap.  So i but that one and installed two grounding points.
I think it is the guitar picking up signal now because when it is unplugged there is no hum and even with the volume turned all the way up.  Before this separation I think I remember trying it without the guitar plugged in and there was really a lot of hum.
Ah! Yes! I was worried about that before about the heater wires not being from pins 9-9, 4-4 to 4-5 etc.  I didn't know but now I do. Thanks for the info on that!  I wasn't sure so I ended up rewiring it so that 9 went to 9 etc.  I should have used different wires haha.
You also mentioned that you can check with a multimeter if it is out of phase?  How do you check that if I may ask.  Sorry, I am still new at all this.
As for mods, I looked some up but I found it might be hard for me to do these mods at least for me.  The spaces are too tight on the 5E3 and I would end up breaking wires etc. hahah because of my clumsy hands.  But maybe I will do those later.  or need some kind of prototype amp to test it out first before I make some wiring and soldering done.
Offline Champ_49
« Reply #52 on: April 21, 2015, 08:32:33 am »
Ok! Pics of the build!
I am done in terms of a stock amp.
It sounds incredible!  I love the sound of this amp!
« Last Edit: April 21, 2015, 08:36:14 am by Champ_49 »
Offline Champ_49
« Reply #53 on: April 21, 2015, 08:34:29 am »
Here are some of the pics for grounding.  Especially the buss.
The buss didn't look the neatest before so I redid this part.  Thanks for looking!
« Reply #54 on: April 21, 2015, 09:23:00 am »
That looks like a 5E3! Good job.
Because that's the way Fender built the original 5E3. Triode just copied the original. Your method is considered better by most people these days.
I don't believe in the heater "phasing" idea.
« Reply #55 on: April 21, 2015, 09:31:06 am »
Something I've been doing the last few builds, I ohm the spr jack neg terminal to the PS main ground point, if it's a short, < 1 ohm, I don't use a ground wire.  If I have "issues"  later, I gator clip that neg terminal to the system ground and if it made things better I add a wire, but so far hasn't made any difference, anyway, FWIW
EDIT:  missed the 2nd page! :BangHead:
Nice build!
« Last Edit: April 21, 2015, 09:34:07 am by shooter »
Offline Champ_49
« Reply #56 on: April 21, 2015, 02:10:16 pm »
Thanks everyone for the kind comments!
« Reply #57 on: April 21, 2015, 04:07:32 pm »
It works and looks good, nice job!
            Brad     :bravo1:
Offline Champ_49
« Reply #58 on: April 22, 2015, 09:23:37 am »
Thanks Brad!
