September 16, 2026, 11:48:49 am
Hoffman Amps Forum image Author Topic: 6X5 rectifier  (Read 8665 times)
Offline Toxophilite
6X5 rectifier
« on: April 21, 2015, 09:19:17 pm »
I have a PT that uses one of these with a pair of 6V6s in parallel and a pair of 12ax7s
I'm planning on swapping it all over to a more convenient chassis and building a 5F11 vibrolux
I've read that the 6X5 is less than ideal and didn't provide a lot of current
I could use solid state rectification but for this build I'd rather stick with a tube rectifier if i can
Any info on/experience with the 6X5?
« Last Edit: April 21, 2015, 09:48:36 pm by Toxophilite »
Re: 6X5 rectifier
« Reply #1 on: April 21, 2015, 10:41:21 pm »
At only 70mA it looks to be inadequate for a pair of 6V6's,  Also it wants to see a 4uF cap.
Offline billcreller
  • 1934
Re: 6X5 rectifier
« Reply #2 on: April 21, 2015, 10:55:31 pm »
Some of the '40s low priced amps had PTs with 70 MA for two 6V6s anyway....    Maybe the 6X5 was cheaper than a 5Y3 back then also (?)
Re: 6X5 rectifier
« Reply #3 on: April 21, 2015, 11:25:09 pm »
An EZ81 (6V filament) would work OK with a pair of 6V6s. A pair of SS diodes and a 100Ω to 250Ω resistor would give you that tube feel. Weber sells a SS copper-cap rectifier with built-in resistor in a tube base module.
     http://www.webervst.com/ccap.html
Offline Toxophilite
Re: 6X5 rectifier
« Reply #4 on: April 21, 2015, 11:39:58 pm »
Hey I forgot about the 6CA4, that's a good idea and I have a few
Also Solid state with a dropping resistor would be a good idea too
THanks!
Offline trobbins
    • Tim's projects and info
Re: 6X5 rectifier
« Reply #5 on: April 22, 2015, 03:02:37 am »
The PT sounds like it had a 2A 6V heater rating?  6V4G would be the next increment up if you had one, and didn't want to go over 2A.
Re: 6X5 rectifier
« Reply #6 on: April 22, 2015, 03:13:57 am »
Talking about 6x5
I don't know if this is a typo, but I read 40uF as first capacitor
and in other datasheet 4uF (???)
http://www.tubezone.net/pdf/6x5gt.pdf
http://www.mif.pg.gda.pl/homepages/frank/sheets/121/6/6X5.pdf
As far as I can know, I can increase the tube voltage handle using a pair of SS diodes in series, but .... there is a trick also to increase the
max first capacitor value ?
I've some 6x5 (may be 6x5gt) and I would like to use it at the best
Re: 6X5 rectifier
« Reply #7 on: April 22, 2015, 12:15:22 pm »
Both tubezone & Frank's say 4uF.
I think the simplest trick for more filtering is to follow the 4uF cap with a small value dropping resistor, then a a larger cap to feed the power tubes.  That way the 4uF cap becomes a "pre-filter" to the 1st stage, and keeps the 6X5 happy.
A diode or resistor might work right after the 6X5 , basically substituting for an inductive input, I guess.
Re: 6X5 rectifier
« Reply #8 on: April 22, 2015, 02:45:53 pm »
Thanks JJasilli
Offline trobbins
Re: 6X5 rectifier
« Reply #9 on: April 22, 2015, 03:49:01 pm »
The transformer primary and secondary winding resistances play a part too.  Perhaps best to try using PSUD2 to better identify what the steady state peak plate current will be.
Offline Toxophilite
Re: 6X5 rectifier
« Reply #10 on: April 22, 2015, 04:41:14 pm »
To further confuse things
On this amp a 6V6 pushpull unit
The main filter caps are 10, 30, 40, (uf) with the 10uf being the first stop after the rectifier
Re: 6X5 rectifier
« Reply #11 on: April 22, 2015, 04:59:26 pm »
Manufacturers are known to cheat with cap values after rectifier tubes.  Even so, 10uF is still small and risks shortening the life of the rectifier tube.
Offline terminalgs
Re: 6X5 rectifier
« Reply #12 on: April 23, 2015, 11:56:14 am »
FWIW, Webcor used 6X5's in lots of tape recorders with 6V6s and 6K6s, usually less than 300V B+.  They always put 20mfd or 25mfd caps as the first reservoir cap.
As for your 5F11 build up.  Check the B+.  If you don't have 330-340VDC with your donor PT, the 6X5/PT is not a good candidate.
Offline Toxophilite
Re: 6X5 rectifier
« Reply #13 on: April 23, 2015, 12:16:19 pm »
Should I be measuring that right at the rectifier? (which isn't currently hooked up to a filter cap?)
Or should I hook up at cap to get a better idea?
Re: 6X5 rectifier
« Reply #14 on: April 23, 2015, 12:38:45 pm »
Always put a cap on it.
Offline trobbins
Re: 6X5 rectifier
« Reply #15 on: April 23, 2015, 03:54:07 pm »
Perhaps if you measure the HT winding voltage and the primary and secondary HT winding resistances, then that would be a start to working out what DC voltage you would get , and what filter capacitance can be used.
Re: 6X5 rectifier
« Reply #16 on: April 24, 2015, 10:34:06 pm »
> say 4uF.
That is an Application EXAMPLE, *not* a Maximum Rating.
There's fine print about other cap values, if you read all which was written on the sheet.
