September 08, 2026, 07:14:00 pm
Hoffman Amps Forum image Author Topic: Cutting and Drilling Board Material  (Read 6270 times)
Offline lkrasner
« on: April 27, 2015, 06:52:34 pm »
Hi, I was wondering if anyone could share their preferred method for cutting the glass epoxy board material? I'm assuming it would be ok to rip on a table saw, but would you recommend using something like a plastics blade?
I've been able to drill them fine with a normal spiral bit, but I now have access to a shopbot cnc router, so does anyone have experience with using a similar machine for drilling out turret holes? what bit do you use?
Re: Cutting and Drilling Board Material
« Reply #1 on: April 28, 2015, 05:21:44 am »
If you have a big sheet of it, I guess the table saw would be the way to go. If you just have the pieces we buy from Doug, the easiest way I've found is a hacksaw. I've tried a 10" chop saw to make a nice straight edge, but the dust is ungodly (and it's fiberglass).
For drilling, I use cheap bits. I generally lose 'em before I wear them out.  :icon_biggrin:
Offline lkrasner
« Reply #2 on: April 28, 2015, 11:07:58 am »
Thanks, That makes sense. How about a band saw? Am I just going to absolutely destroy the blade? I suppose a freehand jig saw would be a good bet since the blades are cheap.
« Reply #3 on: April 28, 2015, 11:35:12 am »
Hacksaw for sure. The stuff is hard on blades. Hacksaw blades are MUCH cheaper than circular or band blades.
That's for DIY one-off. If you are sawing acres of boards you may explore other choices.
Turret holes are just drill-bits. Why make it complicated?
LARGE holes, I had success with a hole-saw, but obsessively clamped to an oak backer to keep the holesaw aligned as it came through. I think a 2" hole and the 18V cordless drill just about managed the massive torque (but I have lots of experience jamming drills and wrenching my wrists with that thing; a heavy drill-press would have been much wiser).
« Reply #4 on: April 28, 2015, 11:35:30 am »
table saw, chop saw, doesn't matter. use a painters mask and push sticks. for best results use a non-ferrous metal cutting blade. dewalt and vermont american sell a decent blade.
http://vermontamerican.com/products/semi-industrial-series-carbide-tipped-circular-saw-blades/
http://www.dewalt.com/tool-part-categories/Metal-Cutting-Saw-Blades.aspx
sometimes i order from these guys.
http://www.eplastics.com/
http://www.eplastics.com/G10-FR4-glass-epoxy-sheet
http://www.eplastics.com/Plastic?search=natural+g10
then have them cut if for me into several widths. it's cut on a CNC machine and they specify 1/4" saw kerf.
Offline Fresh_Start
  • noob de Lux
« Reply #5 on: April 28, 2015, 10:27:31 pm »
Carbide drill bits. Hacksaw. Dust is nasty so if I need a different width, I buy the needed width elsewhere. (Sorry Doug!)
Chip
Quote from: jjasilli
Quote from: PRR
Offline lkrasner
« Reply #6 on: April 29, 2015, 09:33:49 pm »
For the record, I ended up cutting it with a large 12 inch plate shear. Worked great and no dust. Good but not perfect edge. I made a cross cut of one of Doug's boards, and cut another down to about 2x4".
I just drilled like usual with a drill press. It really goes by pretty quick. Some form of cnc machine would be nice just to get perfect alignment, but thats  just for looks. I use a normal drill bit and it seems to work fine. If I were doing a lot of boards I might invest in a carbide bit, but even a dull bit does OK on this stuff. With paper taped onto the board as a guide, the dust is minimal.
