September 14, 2026, 07:06:21 pm
Hoffman Amps Forum image Author Topic: Has anyone tried a resistor or pot between the PS and G2 in a 5F1 amp ?  (Read 4480 times)
(with the obvious purpose to reach early crunch effect)
Yes, adding a screen resistor is a standard Champ upgrade.  See, e.g., my VibroChamp Schematic attached.  You can increase the value of the resistor for effect.
I'm suspicious of pots.  Another alternative is a SW to select between R values in pentode mode; maybe also add triode mode.
Thanks JJasilli
which was your personal reason on adding this mod ?
Was the fact that is "good practice" to add a G2 resistor for G2 protection purpose
or you were looking for earlier compression effect ?
p.s.: A rotary swith with multiple resistors ......... interesting idea
« Last Edit: April 28, 2015, 09:43:00 am by kagliostro »
I did it for "good practice", not for tone.
BTW I tried the KOC mod of 2.2K screen resistors in an EL-84 amp, but didn't like it.  Tried some in-between values but didn't notice much difference.
