September 15, 2026, 01:18:13 am
Hoffman Amps Forum image Author Topic: Serial FXLoop - How to add a parallel function ?  (Read 4805 times)
« on: May 02, 2015, 08:44:50 am »
This FXLoop is a kit that you can find in the web, it is a serial FXLoop, but a friend would like to add a parallel switchable option
the problem (to me) to have things clear in mind, is the 2.2M resistor (I think it acts as a virtual earth)
so I'm not able to decide exactly how to arrange the added part to obtain parallel function
I was thinking to connect the junction of the 22n cap / 500p cap (send side)
with the junction of the 47k resistor / 22n cap (return side)
all with an in series switch to insert or disinsert the parallel and an in-series resistor (lot of doubt about proper value)
But, as told, the virtual earth presence confuses me a lot
Which will be your idea about ?
Many Thanks
p.s.: I hope the circuit was correctly reverse engeenered
« Last Edit: May 02, 2015, 10:20:24 am by kagliostro »
Offline VMS
Re: Serial FXLoop - How to add a parallel function ?
« Reply #1 on: May 02, 2015, 06:15:55 pm »
Aiken has article that shows the summing feature for this type of feedback-amplifier:
http://aikenamps.com/index.php/designing-single-stage-inverting-feedback-amplifiers
« Reply #2 on: May 03, 2015, 02:59:02 am »
Many Thanks for the link VMS
I hope I'll be able to understand all that math :huh:
Offline VMS
« Reply #3 on: May 03, 2015, 03:40:11 am »
If you compare your loop to this loop, then for unity gain you would use 2,2M resistor, I think.
« Reply #4 on: May 03, 2015, 06:14:49 am »
Yes, may be correct
I think I'll try with a trimmer as to establish a right value for the in-series (on parallel signal) resistor
As injection poit I think (as told) to the junction of the 47k resistor / 22n cap, but not sure of that at all
EDIT: I modified "my" schem and seems more readable, I added the mod for parallel/serial action
do you think it is correct ?
what about to connect the 2.2M resistor to ground via the switch when in serial mode ?
in the schem you posted there is a ground connection on the switch, but to me didn't seem indispensable
« Last Edit: May 03, 2015, 07:35:40 am by kagliostro »
Offline VMS
« Reply #5 on: May 03, 2015, 08:11:50 am »
Yes, may be correct
I'm not really an expert on these but to me it looks similar to the picture I posted.
You have to try it, probably you wont here any difference.  :dontknow:
« Reply #6 on: May 03, 2015, 10:36:13 am »
Thanks Again VMS
