June 10, 2026, 10:41:05 pm
Hoffman Amps Forum image Author Topic: Blues Junior Conversion- complete! +vids  (Read 19688 times)
Offline bakerlite
  • Don't forget to play it...
« on: May 13, 2015, 07:05:00 am »
Hi -
Embarrassingly I cant make sense of the Primary hook ups on the fender export transformer - wall voltage is 230v here so I am hooking it up for that but I seem to be getting something wrong as the black red seems to go nowhere....
attached is my estimation of the hookup
here is a link to full schem - https://guitarrasegambiarras.files.wordpress.com/2013/11/amp.gif
can anyone help?!
« Last Edit: May 31, 2015, 03:57:06 am by bakerlite »
Cheers,
Bakerlite
Offline bakerlite
Re: Blues Junior Conversion- Stuck at the start!
« Reply #1 on: May 13, 2015, 07:14:28 am »
http://www.ampix.org/albums/userpics/10003/Blues_Junior.pdf
thats a better document for the hookup as it gives all scenarios... 100/230/240
Maybe I am overcomplicating it and black/Red is  just another no connection.
Cheers,
Bakerlite
« Reply #2 on: May 13, 2015, 07:32:25 am »
I imagine you can figure out the primaries by doing a resistance reading on your meter
Looks like you have 5 wires total
White is common to all the hook ups
Measure from the white wire to all the others and see what they read?
100v - lowest reading
120v -
230v -
240v - highest reading
They should line up in this order by DC ohms on your meter
You can hook up the tranny on the bench and read the secondaries to see if you have it correct
You should have around
20.5 vac across the two browns
261 vac across the two reds
6.6 vac across the two greens
« Last Edit: May 13, 2015, 07:41:21 am by EL34 »
« Reply #3 on: May 13, 2015, 08:06:12 am »
The BLK/RED always connects to P7 whether its strapped for 100V, 230V, or 240V operation. See if this pic helps. The only question I have is there will be two wires on P5. Is that possible?
« Reply #4 on: May 13, 2015, 08:07:45 am »
That drawing makes my head hurt Steve  :icon_biggrin:
« Reply #5 on: May 13, 2015, 08:14:28 am »
I just noticed that the two links you posted show different schematics! Especially in the area of the PT jumpers.
« Reply #6 on: May 13, 2015, 08:29:31 am »
If I am not mistaken I think he is gutting the amp and will need the wire colors for a new hookup
I am thinking the main board has already been removed from the amp and so the plug in connectors are gone
I cut all those terminals off the wires when I did my conversion
I only had black and white wires since my tranny was a US model
Offline bakerlite
« Reply #7 on: May 13, 2015, 09:14:40 am »
Sorry for the confusing diagrams in the OP.
I think from the service manual:
...that i have it figured....
Cheers,
Bakerlite
« Reply #8 on: May 13, 2015, 09:18:54 am »
Yes
« Reply #9 on: May 13, 2015, 09:28:25 am »
Ok, that is different
I was looking at the image you posted at the top
You have dual primaries
« Reply #10 on: May 13, 2015, 09:54:58 am »
The pic in the first post shows a domestic PT on the left and an export PT on the right.
« Reply #11 on: May 13, 2015, 10:04:19 am »
I zoomed in and it went to the domestic
I should not get involved in post when I am doing 3 things at the same time  :icon_biggrin:
Offline bakerlite
« Reply #12 on: May 13, 2015, 10:43:29 am »
thanks you guys are the best.               even Doug... :icon_biggrin:
While I am here - I know its only a small amp but I am considering using a 2 stage switch , its a nice 10A/15A carling switch....  its  all pins  off  and then first position shorts pins 1 and 2  and then second position shorts 3 and 4 (as well as but seperate to 1 and 2)
I was thinking of wiring it like the bigger amps with 2 switches...so i would  only switch one side of the PT primaries using tabs 1 and 2 (as opposed to both in Doug's layout using the standard switch) and leave the other side of the PT permantly hooked up.
And then maybe using 3 and 4 to switch "AFTER?" the rectifier and before the filter cap?
how does that sound?
Cheers,
Bakerlite
« Reply #13 on: May 13, 2015, 11:23:48 am »
Talking about a three position progressive switch, right? And you want to have a single switch for off, standby, and operate? That'll work fine. Here's some more info on that switch...
     http://el34world.com/charts/SwitchDPST.htm
Offline bakerlite
« Reply #14 on: May 13, 2015, 11:26:02 am »
exactly! thats the one.
 :thumbsup:
Cheers,
Bakerlite
« Reply #15 on: May 13, 2015, 11:48:46 am »
Offline Fresh_Start
  • noob de Lux
« Reply #16 on: May 13, 2015, 04:30:52 pm »
I stock that switch on this page
http://hoffmanamps.com/MyStore/catalog/Switches.htm
Doug - I'm really glad you started stocking that switch (although probably a long time ago).  I bought a few 4 or 5 years ago and only have 1 left.  Expected to have to look elsewhere for it.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #17 on: May 13, 2015, 05:51:10 pm »
Thanks Chip.
It took me a long time to find them at a decent price so I could re-sell them at a decent price
Offline bakerlite
Re: Blues Junior Conversion- Getting there!
« Reply #18 on: May 14, 2015, 09:37:24 am »
All good with the PT hookup - fortunately I didnt get to use any of that one shot PT smoke :icon_biggrin:
7.2v
22v
268v
unloaded.
Have to say - Dougs boards are fantastic! Not to mention visualy pleasing too!
Cheers,
Bakerlite
Offline bakerlite
proposed blues junior mods....
« Reply #19 on: May 19, 2015, 03:19:17 pm »
Ok - so I am almost there - all the donkey work done - just got to drop the board components on top  and I am there.
Before I do there are a few component changes I'd like to make based on experience of using this cream board BJ and known exisiting mods for it.
1) Instead of c25 as a 47uf cap use 100uf to stiffen it up a bit (to compliment using a TO22 output transformer and  cannibis rex speaker)
2)Increase preamp voltage by replacing the preamp plate resistors r3 and r8  from 100k to 82k and the filter cap balance resitors r48 and r49 from 10k to 2.2k
3)replace bass cap  (c6) with 0.1uf
4)replace mid cap (c7) with 0.015uf
I have heard legend of some people doing somethiing called a "twin stack mod" by  attaching the centre lug of the mid to ground but I dont understand what it does (compared to the above which are simple component changes)can anyone explain what that does???
anyway... thats what I'm considering.
no alarm bells?
Cheers,
Bakerlite
Re: Blues Junior Conversion- mods?
« Reply #20 on: May 19, 2015, 03:30:36 pm »
I would get the amp working first and then do mods
« Reply #21 on: May 19, 2015, 03:35:39 pm »
I'd leave the plate resistors alone and just mess with R49 if the intention is to just increase preamp B+ (for more headroom?)
If you decrease R48 you will probably increase the gain of the PI. Those EL84s are easy to drive (or overdrive). So you can probably expect earlier distortion.
Offline bakerlite
« Reply #22 on: May 20, 2015, 08:04:02 am »
you are right... I'll do a seperate mod thread when its up and running - too eager!
regarding the stock BJ l.e.d: it picks up the power through the heaters and a 180k resistor - neither of the heater rails are + or -  are they so it doesnt matter which side I stick on the resistor?
Cheers,
Bakerlite
Re: Blues Junior Conversion- more Qs...
« Reply #23 on: May 20, 2015, 08:26:13 am »
I won't matter which side the resistor connects to, but the value of the resistor should be 150 or 180 ohms, not k-ohms.
Offline bakerlite
Re: Blues Junior Conversion- assembled
« Reply #24 on: May 21, 2015, 10:55:10 am »
So just retired the iron at last!
Time for a cup of tea a markie and a schematic I can scribble all over to recheck everything and then its cookin time!
Cheers,
Bakerlite
« Reply #25 on: May 21, 2015, 11:34:41 am »
Looks like it's coming along
Offline bakerlite
« Reply #26 on: May 21, 2015, 05:35:19 pm »
So one of my el84's seems bad outa the box- even if I swap them the 0.6mv draw follows the tube so theres no cigar tonight.
Also the heater voltage seems a bit High what do you think? anything else look alarmingly on the high side?
Ill probably switch the PT primaries from 230 operation to 240 -
wall voltage is 232 here so it may just be enough to lower the heaters.
« Last Edit: May 21, 2015, 05:41:53 pm by bakerlite »
Cheers,
Bakerlite
Offline bakerlite
« Reply #27 on: May 23, 2015, 08:29:45 am »
Well I have re wired for 240v operation and managed to get heaters down to 6.5Voltages at PT (AC) :
heaters:  6.49v            bias: 19.8v                 HT: 244v
Ref points from hoffman blues junior conversion schematic:   X=270v      y=277v             Z=315v             B+=330v
Cheers,
Bakerlite
« Reply #28 on: May 23, 2015, 08:34:25 am »
Is it working?
« Reply #29 on: May 23, 2015, 08:48:39 am »
RE: V3 cathode voltage...
I've never seen 163v on the cathode of a LTP PI. Are you sure about that reading? Do you have the correct value resistors in the cathode circuit, in particular, R21, R24, and R26?
Offline bakerlite
« Reply #30 on: May 23, 2015, 08:58:19 am »
yeah v3 had me scratching  - what a fool - incorrectly attached ground cathode circuit - and to think I had prided myself in double checking everything :(
So V3 now looking more like :
pin 1 - 201      pin 6 - 190
pin 2 - 38v      pin 7 - 40v
pin 3 - 60v      pin 8 - 60v
Cheers,
Bakerlite
« Reply #31 on: May 23, 2015, 09:40:33 am »
Sluckey beat me to it
Those voltages sounded really high like the cathode resistor was wrong or some kind of grounding issue
Offline bakerlite
« Reply #32 on: May 23, 2015, 09:42:24 am »
Is it working?
sorry I missed that post - yes it is kind of sounds ok on top 3 strings but distorts badly when i play the lower strings or dig in with the fingers .
I wonder could i have done damage (either to the meat cap c40  or tube in v3 )           running v3 at those voltages even just for the time it took to take voltages when i was doing first power ons...
Cheers,
Bakerlite
« Reply #33 on: May 23, 2015, 09:49:15 am »
I would look for something else wrong, like the other thing was wrong  :icon_biggrin:
Offline bakerlite
« Reply #34 on: May 23, 2015, 09:51:15 am »
 :l2:
fair point!
just that little cap is only rated for 50v and figured is there was 150+ hanging around i ma have torched it
Cheers,
Bakerlite
« Reply #35 on: May 23, 2015, 09:55:06 am »
Put any cap in it's place to check it
Offline bakerlite
« Reply #36 on: May 23, 2015, 12:36:24 pm »
So i went throught with a fine tooth comb and i am confident there are no more errors,  well i am gonna leave this till moday as I am using a pair of borrowed output tubes that I havent a clue the age/condition so when I have a new matched pair ill be able to rule them out as the cause
The crackling/distortion is only present if I dig in - engaging the Fat switch or having the meat control anywhere past zero seems to either cause it or make it worse
it has brief moments of sounding awesome! so hopefuly will be worth the wait if i can figure this out.
Cheers,
Bakerlite
« Reply #37 on: May 23, 2015, 02:05:54 pm »
Disconnect the NFB from the speaker jack. Get better? If so, reverse the OT primary plate leads and reconnect the NFB wire.
Offline bakerlite
« Reply #38 on: May 23, 2015, 03:31:39 pm »
Oh man that could be it. At work now so will try that tomorrow , I wouldn't mind but I read that very thing happened to someone else here and I made a mental note to think of it at the end of the build.
Must be filed a way with the rest of the mental notes like tidy my work room and what not.
thanks guys
Cheers,
Bakerlite
« Reply #39 on: May 23, 2015, 04:51:03 pm »
I don't know if you've seen this but it is an excellent way to double check an amp build with it's schematic.
We've seen a good number of guys who couldn't find what was wrong with their build and using this method they found it.
Doug did a great job on this example;
http://el34world.com/Forum/index.php?topic=17701.0
                   Brad     :icon_biggrin:
Offline bakerlite
Re: Blues Junior Conversion- complete!
« Reply #40 on: May 25, 2015, 01:44:55 pm »
For sure that way is great. I always print of a schematic I can scratch out with a sharpie and that's what I did. But for some reason I scratched out the ground at the same time as scratching out the cap so all in one go if you know what I mean. Anyway lesson learned...
As it turns out the hookup wire from c6 to the treble pot was damaged Internaly somewhere. After sluckey last idea didn't work for me I sat down with the.trusty chopsticks and found it pretty quick luckily.
So popped in some el84m Mil tubes in there and they are biasing up within 0.4mv (ma)
The amp sounds killer like so much better than it did before the conversion and I been on the same stage as it for 4 years so I would know! !
Very nice attack and sustain and   clarity. It's still a blue's junior just a really nice one  :)
The only thing now is an fx loop as reverb is essential but I promised another topic for mods.
Thank you all for steering me on.  :occasion14:
Cheers,
Bakerlite
Offline JPK
« Reply #41 on: May 25, 2015, 01:57:42 pm »
Sound clips please!!!
Congrats!
I love tubes
« Reply #42 on: May 25, 2015, 02:11:40 pm »
Good deal Liam,
Glad you got it sorted out
Yes, some sound clips would be great
Offline purpletele
    • Vallis Enterprises, Inc.
« Reply #43 on: May 25, 2015, 02:21:59 pm »
Bakerlite,
Do you have room to mount an effects board somewhere in that chassis in the future?  Where are you going to put the jacks?  Do you have an extension cabinet jack in your rig?  I am getting ready to start the same project and was considering the effects loop as well.  I have a new chassis coming, I am anxious to see if I can maximize this chassis.  Right now I have a fuse, line out, axillary speaker and main speaker that needs to be installed.  Not sure I can get an effects loop pair of jacks in the frame.   :dontknow:
That's a great feeling when a projects goes right!
« Reply #44 on: May 25, 2015, 02:34:01 pm »
Check out this device for a self contained effects loop using a sub miniature tube
http://riotdevices.com/products/accessories/
Offline bakerlite
« Reply #45 on: May 25, 2015, 02:49:07 pm »
It will take some persuading thats for sure -
I think I can squeeze fx loop plus a  standard and ext speaker sockets  but that will be very very tight.  no way could I fit a line out too.
I would also prefer to use a heavy duty switch for ohms instead of a double switching switchcraft jack which I decided against as if that fails something could go very badly with the Output section.  So for now I hae not wired the ext speaker.
I am on the lookout for a very small form factor switch for the ohms. but first priority is the fx loop as reverb is a must!
Cheers,
Bakerlite
« Reply #46 on: May 25, 2015, 02:58:23 pm »
Offline bakerlite
« Reply #47 on: May 30, 2015, 04:45:59 pm »
Blues junior Hoffman 1:
Just a snippet. Was testing a reverb pedal
Cheers,
Bakerlite
Offline purpletele
« Reply #48 on: May 30, 2015, 07:21:23 pm »
Do you have the effects loop in place or are you going direct into the main input with the reverb pedal.  I haven't used an effects loop so I am not sure I need one to begin with, but if I did I would think the reverb or chorus would be processed through that loop, is that correct?
If you do have the effects loop in place does it create any noise at all?
Offline bakerlite
« Reply #49 on: May 30, 2015, 08:04:01 pm »
Hey Pete sorry I meant to get back to you on the other thread but am away gigging this week. The guitarist is loving his new improved blues junior!   Yes the verb is in the loop. I inserted it after the treble and before v2a 10k resistor.  Space is very tight. It's located next to the speaker jack so this places the loop components perpendicular to the power transformer. It was noisey but after changing the b+ ground for the loop to the cathode of v2a ground it helped but not completely  so I fabricated a 4" x 2.5" shield of thick metal plate and placed it over the PT and grounded it to chassis. This removes all hum and noise.
As regards the mods from billm you asked about the tone stack mods are just the 2 caps for mid and bass so yes you could apply them easily to this circuit as it's the same. As for the presence mod you have I will have to check when I get back and not using this tiny phone but maybe someone else could chime in as far as I remember there  is a 7.5 resistor in dougs layout  where I believe you could insert the 10k pot but I need to look at that again.
My one gripe with my build is that it does in fact need the presence mod as we are rolling off treble where ideally we'd like to be rolling off just the higher frequency so I would recommend persevering  with your research on the presence mod  .
As for the clean boost I don't know anything about it but if it comes with instructions just cross reference dogus layout with the schematic from fender I posted above and you should be able to find all relevant points to hook it up?
I will try and get better video showing longer and more varied playing, that was just us making sure the reverb was working in the loop before the gig.
Did you mention chassis? I badly need a blue's junior chassis If you know where to get one?!!! I have a spare bj cab I'd lI've to repurpose but it didn't come with a chassis..
Cheers,
Bakerlite
