September 18, 2026, 05:25:00 pm
Hoffman Amps Forum image Author Topic: 1K 25 WATT resistor  (Read 6405 times)
Offline Mook
1K 25 WATT resistor
« on: May 14, 2015, 06:34:52 am »
The Trainwreck Express and Liverpool both use a 1 watt 25 watt power resistor in the place that other amps use a choke.
Why 25 watts?     Seems to me a regular 5 watt will work, here.
Discuss?
Mook
Re: 1K 25 WATT resistor
« Reply #1 on: May 14, 2015, 06:57:55 am »
The Blue Guitar has updated DIY schematics showing 25W, 5W or a choke.  I agree that 5W should be more than adequate.  But, it depends on how hot the Resistor actually gets.  Resistance increases with heat.  If a 5W resistor gets hot, its resistance will change.  So the tube's performance, and tone, will vary -- possibly as a result of something so mundane as how long the amp was left ON.  A 25W resistor is less likely to vary its value due to the watt it dissipates in this circuit.  That's the only explanation I can think of.
Offline vibrolax
« Reply #2 on: May 14, 2015, 09:38:07 am »
I agree with your analysis.  In my TW Express build (6V6's) I used a 10W cement resistor for the R between the plate and screen node.  I calculated about 6 mA running through that node at idle.  Maybe 12 mA at peak.  So I * I * R = 0.012 * 0.012 * 1000 = 0.14W. A 1W resistor would be sufficient.
Working it backwards, for a 5W resistor:
5W = I * I * 1000
I * I = 5 / 1000,
I * I = 0.005
I = sqrt(0.005)
I = 70.7 mA
So a 5W 1000 ohm resistor is rated to dissipate heat from 71 mA current.
Using a safety factor of 4, that's 18 mA.
I don't know what the screens currents in a cranked pair of EL-34's are, but it can't be anything remotely close to needing a 25W resistor.
The preamp section draws a few mA.
If anyone can explain the justification for 25W resistor here, other than blincly copying what Ken Fisher put in his amps, I'd be most curious.
Regards,
Jon
Jon
Offline vibrolax
« Reply #3 on: May 14, 2015, 09:45:39 am »
Interesting theory.  I have another 1K 10W cement resistor.  I could check the temperature coefficient from the datasheet, then measure how the resistance changes with temperature, but that will have to wait for a day when I have my temp measurement setup assembled.
Jon
Jon
Offline vibrolax
« Reply #4 on: May 14, 2015, 10:20:14 am »
Referering to this data sheet for Xicon cement resistors: http://www.mouser.com/catalog/specsheets/XC-600041.pdf
The temperature coefficient is +/- 350 ppm / degree C.  Hmmm, the sign is +/-, so it doesn't say whether the resistance increases or decreases with increasing temperature.
I calculate a resistance change of about 25 ohms between 30C and 100C.  That's about 2.5% for a 1000 ohm resistor.
The heat rise chart shows a 70C rise occurs at % rated load of about 20% for 15W & 25W resistors, and 40% of rated load for 5W.
I wouldn't be bothered by a 2.5% resistance change.
Of course, there may be other factors involved, but I'll admit ignorance.
Jon
Offline vibrolax
« Reply #5 on: May 14, 2015, 10:44:10 am »
Mistake! Power dissipation increases with the square of the current.  So to limit the dissipation by a factor of 4 = 5W / 4 = 1.25W
I = sqrt(1.25 / 1000) = 35 mA
Jon
Offline Mook
« Reply #6 on: May 14, 2015, 05:44:36 pm »
another funny question regarding this is:
Mark Abbott drew the schematic for the Liverpool as well.   In his comments, he said that in order to use 1/2 power (2xEL84) the resistor should be changed to a 2K.   But, I don't see the reason for that.....that's barely dropping any volts.
Mook
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #7 on: May 14, 2015, 06:09:44 pm »
Screen current in overdriven EL34's might surprise you.  I use 10W 1K screen resistors in my big EL34 amps, and I ain't the only one.  That guy probably knew what he was doing when he used a 25W in place of the choke.
