September 13, 2026, 04:02:03 pm
Hoffman Amps Forum image Author Topic: Did a resistor swap  (Read 4696 times)
Offline hesamadman
Did a resistor swap
« on: May 25, 2015, 11:00:51 am »
After battling a noise with my 30 watt for sometime, I decided to do a resistor swap in the whole amp (well preamp anyway). I originally used metal oxide resistors from parts express. Seems like a good idea right? Metal oxide supposedly pretty quiet components. However I began to question these guys due to the cost. Just under a nickle each (wholesale). Also parts express is known for speaker building components and not so much amp. It was a long shot but I decided to order some metal film resistors from Doug. Changing all my plate resistors. Cathode. And all in between.  Don't ask me why, but the amp was soooo much quieter. Turning the gain at noon you would have had an audibly annoying hum with master set at 2.......well the reduction this made was tremendous. Pretty excited about it.
Re: Did a resistor swap
« Reply #1 on: May 25, 2015, 01:39:31 pm »
Dramatic, huh? It's really the preamp plate resistors that will make the most difference.
I was not aware that you could buy "metal oxide" resistors; I knew you could buy metal oxide varistors and oddball kinds of things. I only knew that for the plain old resistors scattered around an amp, "metal film" resistors were the ones to get. Good to know.
Offline hesamadman
« Reply #2 on: May 25, 2015, 03:05:43 pm »
Metal oxide film rather
Offline hesamadman
« Reply #3 on: May 25, 2015, 03:06:20 pm »
My guess was gonna be plate resistors being the biggest affect
Offline MakerDP
« Reply #4 on: May 25, 2015, 07:35:55 pm »
https://www.tubesandmore.com/products/resistors
Metal Oxide resistors are usually used for the 1 to 3 watt range in the power supply or flame-proof screen resistors.
Carbon Comp or Metal Film everywhere else... I prefer metal film too.
« Reply #5 on: May 25, 2015, 11:08:02 pm »
Yes, metal oxide (MO), to my understanding, for higher wattage than metal film (MF).
I think out of the different types of R's being made that MF is the quietest, with MO being the next quietest. Carbon comp. (CCR) being the nosiest.
It doesn't make sense to me that MO R's were a hiss noise source? But maybe they were 'cheap' badly made MO R's?
                        Brad     :think1:
Offline hesamadman
« Reply #6 on: May 26, 2015, 05:59:27 am »
Well most certainly cheap. That's why I used them. Ha.
