August 29, 2026, 01:12:14 pm
Hoffman Amps Forum image Author Topic: Looking for info on diode clipping  (Read 7875 times)
Offline hesamadman
« on: May 27, 2015, 08:54:39 pm »
Been playing with some diode clipping in a couple of my amps. Ive seen a lot of videos of people doing it and using a double throw switch which gives two different values of clipping. Well, I am getting some neat tones but my problem is loss of volume. I lose way too much. Any idea how to remedy this?
Re: Looking for info on diode clipping
« Reply #1 on: May 27, 2015, 10:50:00 pm »
Add gain after clipping.
« Reply #2 on: May 28, 2015, 12:47:20 am »
This is how the JTM60 does it.
Offline VMS
« Reply #3 on: May 28, 2015, 07:03:19 am »
You can put few diodes in series so that Vt voltage increases from 0,7V to 1,4V or 2,1V and so on.
Or you can use zener diodes.
Offline hesamadman
« Reply #4 on: May 29, 2015, 07:08:21 am »
I was hoping to do this without adding a tube. But if not possible I just wont mess with it on this amp. But can you explain your method of the two diodes in series? Where do I put those in the circuit? Im pretty sure I used zener diodes on the mod but I can double check as I just had them clipped in.
Right now the diodes are installed to ground with the drop down resistor right before the grid of V2a of my 2204. Two diodes. One down flowing. One up flowing.
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #5 on: May 29, 2015, 06:33:59 pm »
Zeners give a sharp clip with a harsh sound.  If you want to try them, hook two in series either pointing towards each other or pointing away from each other.
A lot of the time when people use multiple regular diodes (e.g. IN4007) in series, they will use more in one direction than in the other.  This more closely imitates preamp tube clipping.
For more fun, try using a resistor and a diode for the cathode of a preamp tube.
One strategy is to get some amount of distortion from the tubes and then clip with the diodes.  See the Marshall 2210 schematic which straightens out to three diodes up and three diodes down.  Or look at my attachment which is a variation of the same idea.
Offline VMS
« Reply #6 on: May 29, 2015, 06:47:26 pm »
Offline Fresh_Start
  • noob de Lux
« Reply #7 on: May 30, 2015, 08:17:36 am »
Thanks VMS. Helpful links.
Chip
Quote from: jjasilli
Quote from: PRR
