August 29, 2026, 02:00:52 pm
Hoffman Amps Forum image Author Topic: 5e3 kit - 6v6 pin 1 to pin 8  (Read 4391 times)
Offline 6v6Pin1
« on: June 01, 2015, 05:24:13 pm »
Why does the layout show pin 1 connected to pin 8 on the power tubes? As I understand, pin 1 is unused. What is the benefit of connecting these pins?
Re: 5e3 kit - 6v6 pin 1 to pin 8
« Reply #1 on: June 01, 2015, 06:07:09 pm »
Maybe some day you will plug some EL34s in the amp. That's the only time you will need that connection.
« Reply #2 on: June 02, 2015, 12:17:04 am »
With metal 6V6, pin 1 is the metal shell and should be bonded to chassis.
I have never seen a metal 6V6, though I have seen one picture. I did know a lot of metal 6L6, but that was a long time ago, and 6L6 is too much for that amp. A true 6550 has a metal base which should be bonded to chassis, but that's way too much tube for a 5E3.
Yes, or EL34, which has G3 on pin 1 and should be tied to low/zero voltage.
If you tie pin 1 low, do NOT run 7027. (Unlikely you would, or that they would even fit a true vintage size 5E3.)
