September 16, 2026, 10:25:03 pm
Hoffman Amps Forum image Author Topic: Pentode/Triode switching = need a 4PDT switch?  (Read 4911 times)
Offline Mook
« on: June 05, 2015, 08:47:27 am »
For a duet of power tubes, yes, we need DPDT switch, but I cannot figure out how to switch Pentode/Triode with 4 power tubes.
Seems you need a 4PDT switch, right?
Offline VMS
Re: Pentode/Triode switching = need a 4PDT switch?
« Reply #1 on: June 05, 2015, 08:58:00 am »
No, here is an example how marshall did it with DPDT on jcm900:
« Reply #2 on: June 06, 2015, 12:28:49 am »
Connect 4 plates together, you have 2 wires.
Connect 4 screens together, you have 2 wires.
Screens go to the corresponding plates, or to B+.
DPDT.
Offline vicentebd
« Reply #3 on: June 08, 2015, 08:13:08 pm »
DPDT.
By the experience, could you  tell me if Pentode/Triode switching, is normal make a "pop" sound ?
thank you
at deluxe reverb level
« Reply #4 on: June 09, 2015, 12:20:41 am »
Probably.
With most switches, the screens will disconnect from B+ (and fall to zero) for an instant, before they connect to plates. Also it is unlikely both sides of a double-pole will break and make at the SAME instant. If the pop is real loud, turn the amp off (or standby) before flipping the T/P switch--- it isn't really something you should change mid-song.
