September 17, 2026, 08:38:30 am
Hoffman Amps Forum image Author Topic: When is it necessary to create a center tap using resistors?  (Read 4164 times)
Offline hesamadman
Was curious when do I need to create a center tap on my PT 6.3v tap using 100ohm resistors. I thought it was when the PT itself did not have a center tap but on some schematics I am looking at, it shows both.
Re: When is it necessary to create a center tap using resistors?
« Reply #1 on: June 05, 2015, 09:16:53 am »
That's right. Talking about a center tap on the heater winding.
Show us one of those schematics please.
Offline hesamadman
« Reply #2 on: June 05, 2015, 09:33:58 am »
Actually I apologize. I was mistaken. Since on the topic. Should the center tap of the 6.3v terminate at the PT CT ground lug as well?
« Reply #3 on: June 05, 2015, 09:51:26 am »
Here you can see someone
http://el34world.com/Forum/index.php?topic=14449.msg136955#msg136955
But those aren't normal conditions, there you have a bridge rectifier that act as a "separator" and resistors are used as to recreate a virtual ground for the DC part of the circuit
Sometime I've hear that in some cases (not good PT construction) some guy disconnect the CT and recreate it via resistors or Humdinger
I think that a Humdinger may be better than a grounded CT in the case of a not perfectly balanced PT, because you can perfectly balance the windings turning moving the wiper to the correct position
« Last Edit: June 05, 2015, 09:53:53 am by kagliostro »
