September 16, 2026, 12:45:15 pm
Hoffman Amps Forum image Author Topic: OT question  (Read 5848 times)
Offline dude
OT question
« on: June 12, 2015, 08:39:19 am »
I have an old single-ended OT, 10K5 @ 8 0hms and 5.2K @ 4 ohms.  Seems a little high for a 6V6.
Which would I get the most volume from, the 6V6 @ 8 ohms (would like to see around 8K) or 6L6 @ 4 ohms (like to see around 5K)? So, seems the OT would be better suited for a 6L6...?
But I want to use a 6V6, should I run it with a 4 or 8 ohm spk.
al
Re: OT question
« Reply #1 on: June 12, 2015, 10:21:48 am »
kinda sorta depends on your B+, the tube chart shows 5k at 250vdc but 8.5k at 315vdc.
Re: OT question
« Reply #2 on: June 12, 2015, 10:26:00 am »
Shooter you preceded me, you are the fastest shooter of the forum  :icon_biggrin:   :thumbsup: :thumbsup: :thumbsup:
+ 1 for Shooter I was about to say the same thing
give a look to the datasheet
http://www.mif.pg.gda.pl/homepages/frank/sheets/121/6/6V6.pdf
« Last Edit: June 12, 2015, 10:43:27 am by kagliostro »
Re: OT question
« Reply #3 on: June 12, 2015, 12:22:34 pm »
fastest shooter
I got the name from an 'ol guy, I was wearing a '40s trench coat one day and he yelled out "hey shooter"
and it stuck!  my actual shooting skills are not that good, 3 outta 5 on a paper plate from my 30-30 at 80yrds, open sights.
Re: OT question
« Reply #4 on: June 12, 2015, 01:41:26 pm »
it is a long long time I didn't shoot
I was fond of standard 22LR rifle shooting at 50 meters
but that was in one other life  :icon_biggrin:
« Last Edit: June 12, 2015, 01:57:21 pm by kagliostro »
Offline dude
Re: OT question
« Reply #5 on: June 12, 2015, 10:05:05 pm »
You guys are crazy, Doc Holiday.... :laugh:
Yeah, I saw that chart but who runs B+ voltage less than 325v yet 250v.
Running 380v B+, cathode biased.
I really can't tell the difference in sound levels between 4 or 8 ohms with the 6V6, just wondering if the PT is getting stressed as the single 6V6 wants around 8K, I believe. So it's either 5K5 or 10K5, my guess is use the 8 ohm speaker...?
Re: OT question
« Reply #6 on: June 13, 2015, 01:12:43 am »
About that choice (10.5k with an 8ohm speaker) you are near the best Zout (you miss only near 1.5k of Zout)
I hope my math is correct
Zout = Va/(Pa/Va)
(where Zout the requested output impedance - Va is Volt at Plate - Pa is the dissipation ammissed for the plate of the tube)
so we have
Zout = 380v/(12W/380v)
12/380 = 0.0315789
380/0.0315789 = 12033.351
Zout = 12033.351ohm
not very far from your 10.5k
You must set a cathode resistor as to have the tube idle near maximum and use a 470R 2-3W resistor watching to the grid dissipation or you can set it at 50-60v below the plate voltage
I hope someone can confirm my math
« Last Edit: June 15, 2015, 12:41:35 am by kagliostro »
Offline VMS
Re: OT question
« Reply #7 on: June 14, 2015, 05:22:45 pm »
I think PRR posted this type of a formula for the cathode resistor value:
Load impedance divided by tube mu times 0,6
10500 / 10 * 0.6 = 630 Ohm
