September 13, 2026, 09:09:57 pm
Hoffman Amps Forum image Author Topic: 5E3 with different PI  (Read 7782 times)
Offline Leevi
    • Rikstone
« on: June 30, 2015, 11:19:40 pm »
Does anyone have experience in using different kind of PI like AB763 PI
together with cathode biased 5E3 power tubes?
Would it work?
/Leevi
Re: 5E3 with different PI
« Reply #1 on: July 01, 2015, 01:31:23 am »
yes. graft in BF deluxe PI. discard NFB loop & insertion 47R. overall gain will be less with LTPI though.
Offline VMS
« Reply #2 on: July 01, 2015, 03:19:22 am »
Maybe something like 5g9 tremolux without the trem and cathode biased.
http://ampwares.com/schematics/tremolux_5g9.pdf
Offline robrob
« Reply #3 on: July 01, 2015, 09:06:07 am »
Yes it will work. A blackface long tail pair phase inverter is a gain stage (the tweed Deluxe's cathodyne phase inverter isn't) so the amp will drive the power tubes harder which is a good thing.
The LTP PI also has a sweeter distortion tone than a cathodyne PI too so it should have a tighter, more modern distortion tone, especially when pushed with pedals near max volume.
RobRobinette.com
Offline Fresh_Start
  • noob de Lux
« Reply #4 on: July 06, 2015, 11:51:12 am »
I could be wrong but think that a gain stage plus cathodyne like the 5E3 has significantly more gain than a long-tailed pair. OTOH cathodyne has unusual distortion when pushed too hard.
Chip
Quote from: jjasilli
Quote from: PRR
Offline robrob
« Reply #5 on: July 06, 2015, 03:07:48 pm »
You are correct Chip and the second half of your post explains why the long tail pair phase inverter is so ubiquitous in post tweed era guitar amps.
RobRobinette.com
« Reply #6 on: July 06, 2015, 03:17:31 pm »
2X or 3X.
Separate gain-stage can develop full gain; long-tail gives half-gain to each side.
Further the separate gain-stage only has to drive the near-infinite load of cathodyne grid, and can be optimized for more gain (less load-pulling grunt). The long-tail typically has to face the power tube grids directly. If these are fix-bias then they should be around 100K, quite low for a gain-stage. (But we often cheat-up to 220K.)
