August 28, 2026, 03:10:45 pm
Hoffman Amps Forum image Author Topic: Stout kit cuts out at high volume  (Read 4664 times)
Offline 6v6Pin1
« on: July 09, 2015, 09:39:02 pm »
I just finished a stout amp and when I turn it up all the way it starts cutting out. From reading, I gather this is parasitic oscillation.
I was hoping someone could give me some things to check.
I checked my voltages against the schematic (I disconnected the feedback resistor):
v1
1: 191.0
3:     1.8
6: 198.0
8:     1.8
v2
1: 275.0
2:     0.0
3:     8.2
6: 289.0
7:     0.0
8:     8.2
v3
3:   10.8
7: 297.0
9: 304.0
v4
3:   10.8
7: 297.0
9: 304.0
Caps
A: 310
B: 308
C: 285
D: 278
Offline markmalin
  • Malin Sweet Loraine
    • Malin Amplification
Re: Stout kit cuts out at high volume
« Reply #1 on: July 10, 2015, 03:43:21 pm »
Can you post some pictures of the inside?
Mark.
"... there are Flying V's and then there are the ones shaped like peanuts..."  - my son at age 9
« Reply #2 on: July 10, 2015, 05:41:55 pm »
Hard to say
Your voltages are different from mine here
http://el34world.com/Hoffman/files/Hoffman_Stout.pdf
What power transformer are you using?
Offline 6v6Pin1
« Reply #3 on: July 16, 2015, 12:30:38 pm »
I finally figured out that I made a mistake wiring the lugs together. The v2 voltages were way out of line and that was the clue. I fixed that and the amp sounds great now.
The transformers are by Hammond for an 18w Marshall.
« Reply #4 on: July 16, 2015, 01:49:06 pm »
Good reasoning!
              :bravo1:
