September 14, 2026, 04:22:33 pm
Hoffman Amps Forum image Author Topic: Fender Switching Problem  (Read 3884 times)
Offline RAJPE
« on: July 31, 2015, 12:24:34 pm »
I have a Hot Rod De Ville 212 which switches on its own for a few seconds from the clean channel to the dirty channel.  I checked the 16 V power supply and was +/- 16.8 volts.  The 330 ohm resistors get hot but not extremely so.  Any suggestions on what else to check?
Re: Fender Switching Problem
« Reply #1 on: July 31, 2015, 12:36:16 pm »
Does the LED color change also?
The problem could be almost anything between the foot switch and the relays. Lot of circuitry for a poor solder connection to hide. Maybe even a bad IC, transistor, diode, cap, etc.
