September 15, 2026, 04:39:47 am
Hoffman Amps Forum image Author Topic: Traynor YBA-3 Custom Speaker config question  (Read 4396 times)
Offline pbman1953
« on: August 04, 2015, 07:03:58 am »
After doing my latest mode I noticed on my schematic a 8 inside a triangle next to the speaker jack drawing.
Does this mean the amp is rated at 8 ohm?
The speaker jacks are wired in series, an option I don't like. Has any other owner re-wired to be parallel?  Traynor had 8 ohm and 16 ohm cabs for this amp. I tried 16 ohm and it does not sound good. It sounds the best at 4 or 2.Most of my cabs are 4 or 8 and I've read that this amp can handle 2 ohm.
 I just want to be safe
Please let me know your opinions
Re: Traynor YBA-3 Custom Speaker config question
« Reply #1 on: August 04, 2015, 08:00:33 am »
There are several different schematics of this amp. Some show a multi-tap OT secondary with a 2Ω/4Ω switch and parallel jacks, some show a 8Ω output. The 8Ω output schematics have that "triangle 8" notation and the speaker jacks are wired such that if you plug into the EXT jack you will disconnect the SPKR jack. I would respect the output impedance on a quad of EL34s. Using a 4Ω cab on the 8Ω jack 'may' be safe, but using a 2Ω cab on the 8Ω jack would be inviting expensive trouble.
I don't own this amp but you can certainly rewire the speaker jacks if you wish. Note that the EXT jack is isolated from chassis.
Offline pbman1953
« Reply #2 on: August 04, 2015, 08:23:56 am »
You're right on the many schematics. Shown below is the link for mine-
http://www.freeinfosociety.com/electronics/schematics/audio/traynor_customspecial_yba3c.pdf
« Reply #3 on: August 04, 2015, 08:41:04 am »
The OT secondary has "8Ω" stated next to it.  There are several numbered triangles in the schematic which seem be test points; see the box in the lower right corner of the schematic.
Offline pbman1953
« Reply #4 on: August 04, 2015, 08:48:23 am »
Ahh, saw that. So I suppose not to go lower than 4 ohm
In that case , it stays as is.
My configs would be-
1- 8 ohm
1- 4 ohm
2- 8's- daisy chained to be 4 ohm
2- 4's - using both jacks to be 8 ohm
I'm covered
