October 12, 2026, 07:35:51 am
Hoffman Amps Forum image Author Topic: Tube dampeners/coolers  (Read 8700 times)
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« on: August 07, 2015, 12:15:28 am »
Question, I just came across a site, thetubestore.com that sells a few items that are supposed to dampen the tubes to increase sound quality etc.  They seem a bit snake-oil like to me, has anyone heard of these, and do they really work:
Kryna Tube Radiators: http://www.thetubestore.com/Parts-Accessories/Kryna-Tube-Radiators
Duenda Criatura Tube Rings: http://www.thetubestore.com/Parts-Accessories/Duende-Criatura-Tube-Rings
Seems the former is a cooling mechanism as well as some kind of dampener, the latter is just a dampener.  Is this really an issue with tubes?
~Phil
Phil Davis
tUber Nerd =|D
Re: Tube dampeners/coolers
« Reply #1 on: August 07, 2015, 03:59:58 am »
Google for "dissipation tube shields"  image search
You'll see a lot of mil spec dissipative shields and you can buy it on the cheap
« Reply #2 on: August 07, 2015, 05:56:26 am »
I have bought tube dampener silicon rings off ebay; I got 8 for around 10 bucks I think. I bought those because I had some microphonic 6SL7 tubes. They do work. The ones that are costing $35 & $100, I think are ridiculous. JMHO.
Then again, I refuse to spend $20 per cap, $3/ resistor, $300 for a speaker, and $50 for a gold infused oxygen-free audiophile power cord too.  :icon_biggrin:
« Reply #3 on: August 08, 2015, 12:03:39 am »
Tube coolers theoretically increase tube life. I've never had a preamp tube die, even after decades of use. They will usually lose emission and have reduce Gm and gain long, long before they ever die.
I've never tried tube dampeners, though I've also not tried to make microphonic tubes work in one of my amps. I believe Tubenit has made some home-spun silicone tube dampeners to tame ringing in preamp pentodes. Perhaps he'll chime in.
Other than those 2 issues, I would advise you not to believe add-on items will make a tube "sound better" though a dampener may reduce the occurrence of microphonics in some tubes.
« Last Edit: August 11, 2015, 09:29:06 pm by HotBluePlates »
« Reply #4 on: August 11, 2015, 09:30:42 pm »
TubeCAD, an on-line journal is showing silcone dampners in a couple of their advertisements.
But John Broskie isn't selling them, he's selling ad sapce to people who are selling them.
And if you can't sell snake oil to audiophiles, then you can't sell anything.
« Reply #5 on: August 12, 2015, 08:44:24 am »
I was looking at V-Caps, copper clad, North of $100 per cap!!! :l2:  I don't mind paying for quality but  :cussing: that's boarding on nuts!
« Reply #6 on: August 12, 2015, 05:26:34 pm »
But copper is cool, and it sounds good too.
« Reply #7 on: August 12, 2015, 08:32:13 pm »
copper is cool
Yup, that's why my latest build has the chassis wrapped in copper foil :icon_biggrin:
« Reply #8 on: August 12, 2015, 11:21:21 pm »
Copper foil rolled with sheets of film plastic costs more than sputtering aluminum on plastic. Production quantities are probably flea-bite scale compared to any sensibly-priced coupling cap. There's undoubtedly a healthy profit margin added, but those caps would always be expensive due to pricy raw material and total lack of economy of scale. So I'm not exactly put off by the price.
I just don't believe you'll hear an improvement that justifies the cost in a guitar amp. Maybe in hi-fi audio if everything else in the chain is as near-perfect as it can be.
The first 5E3 I built has "audiophile resistors" and copper-foil paper-in-oil caps. Know what it sounds like? A tweed Deluxe... I think after that episode I've paid for the right to the opinion that circuit architecture is a much greater factor in determining the amp's sound, though I can & do hear the differences between varieties of some parts.
Can't knock someone who trying to make a buck in the tube business.   :icon_biggrin:
Agreed. My real point (not really articulated) is it might be a mistake to assume Broskie endorses everything that appears in ads on his site. He might, but if I read into his writing correctly he's more likely to mean, "this is a good product if you have an application which requires it," rather than, "you must have this or your amp is garbage."
« Last Edit: August 15, 2015, 02:15:27 pm by HotBluePlates »
    • Daviszone
« Reply #9 on: August 15, 2015, 01:26:22 pm »
Lots of great information, thanks guys!  I forgot I'd even posted this heh!
Phil Davis
tUber Nerd =|D
Offline trobbins
    • Tim's projects and info
« Reply #10 on: August 15, 2015, 04:51:04 pm »
Both those items would do 'something' if you had a noticeable related problem.  But the cost, the snake-oilish description, and lack of any relative assessment/review put them in the audiophile esoterica bin.
Microphonic, hum coupling and heat related issues are best approached with an understanding first, rather than a possible cure.  I hadn't seen the dampeners before - I might add a picture to:
http://dalmura.com.au/projects/Microphonics%20in%20valves.pdf
Offline denitronik
« Reply #11 on: August 16, 2015, 07:22:48 am »
It's cheaper just to replace the tubes!
