October 12, 2026, 10:31:22 am
Hoffman Amps Forum image Author Topic: 5E9-A Trem Groudning Questions  (Read 3810 times)
Offline fdesalvo
  • "...I can walk!!"
    • Forgotten Gear Restorations
« on: August 14, 2015, 04:21:15 pm »
Ello, ello!It's been quite some time, gang. I hope you all are doing exceedingly well.I'm about finished amassing my components, but I have a question or two. I'm not using the brass grounding plate, but have a few grounding points for the preamp and power section a'la Hoffman. Where do I ground the trem speed pot and foot switch jack? Thanks!
FDeSalvo,
Principal Engineer & Owner,
Re: 5E9-A Trem Groudning Questions
« Reply #1 on: August 14, 2015, 07:26:47 pm »
The parts your mentioned are connected to a specific tube in that amp (using the original Fender layout, it's the 12AX7 closest to the output tubes). Ground those parts to the same place that 12AX7 is grounded.
