October 11, 2026, 05:35:46 pm
Hoffman Amps Forum image Author Topic: warning on Fender pro 6G5A layout diagram  (Read 7038 times)
« on: August 21, 2015, 01:58:39 pm »
This fender pro 6G5A layout shows the screen wire going to the input grid pin 5
It should be going to pin 6 right next door
This image shows the error
« Last Edit: August 21, 2015, 04:40:52 pm by EL34 »
Re: warning on Fender pro 6G5A layout diagram
« Reply #1 on: August 21, 2015, 02:29:02 pm »
this work?
« Reply #2 on: August 21, 2015, 02:46:55 pm »
How come the quality went down?
Seems to be less sharp?
« Reply #3 on: August 21, 2015, 03:26:55 pm »
I figured out how to do it
I removed the PDF's from the library that were incorrect
I split the layout and schematic into separate PDF's
I uploaded the new PDF's to the library
http://el34world.com/charts/Schematics/files/fender/Fender_Pro_6G5A_Layout.pdf
http://el34world.com/charts/Schematics/files/fender/Fender_Pro_6G5A_Schematic.pdf
The layout looks like this now
« Last Edit: August 21, 2015, 04:26:22 pm by EL34 »
« Reply #4 on: August 21, 2015, 03:30:45 pm »
I can put the schematic and layout back in a single pdf if you want.
« Reply #5 on: August 21, 2015, 04:25:39 pm »
Thanks Steve
I split it into two PDF's, layout and schematic
If you want to take my two PDF's and combine them, that would be cool
« Last Edit: August 21, 2015, 04:28:47 pm by EL34 »
« Reply #6 on: August 21, 2015, 04:28:44 pm »
What I mean is I can COMBINE the two pdfs you made into a single pdf. Like this...
« Reply #7 on: August 21, 2015, 04:29:15 pm »
yes, I re-read it and was typing the same time as you  :icon_biggrin:
« Reply #8 on: August 21, 2015, 04:31:25 pm »
I found a free on line site that did that for me
I could combine my two images in one large image file and have that site create one PDF
« Reply #9 on: August 21, 2015, 04:38:47 pm »
Thanks for sharing Doug
« Reply #10 on: August 21, 2015, 05:22:57 pm »
glad you got it, The file size when I put it back together was 1.3meg, so on the pdf editor I used, I had to re-size and that was the next step down
I use an old version of pdf creator
« Reply #11 on: August 21, 2015, 05:54:51 pm »
Got cha, Thanks for trying
I ended up taking screens shots of the PDF pages on a 23 inch monitor and then pasting them as .png's
Then used a free on line program that converted my .png's into PDF's
« Reply #12 on: August 21, 2015, 11:30:18 pm »
If you have a windows machine, you could paste the pics into Powerpoint (1 per slide), then "Save As" and select PDF as the output file.
No idea what file size it would create, but as long as you don't start with huge-byte-size images (like bitmaps), then it'll probably come out okay.
« Reply #13 on: August 22, 2015, 06:53:09 am »
I don't have powerpoint installed, but thanks for jolting my brain
I just realized I can do this with Visio and do a much nicer job
Here's the new version I just uploaded
http://el34world.com/charts/Schematics/files/fender/Fender_Pro_6g5A.pdf
The layout and Schematic are both in this PDF
« Last Edit: August 22, 2015, 06:55:12 am by EL34 »
« Reply #14 on: August 22, 2015, 07:49:09 am »
Looking sharp! Good job!
« Reply #15 on: August 22, 2015, 08:06:54 am »
Dang, is there anything Visio cannot do?
I probably have not even explored a fraction of it's features
