September 17, 2026, 10:18:02 am
Hoffman Amps Forum image Author Topic: Need advice on Stereo Amp to play vinyl  (Read 5535 times)
Offline x44d80
« on: September 30, 2015, 01:55:10 pm »
My son dug out all my old vinyl records. We have equipement to play them, it's just not very good.  I was going to buy a old Pioneer, Marantz or Kenwood solid state amp but I started thinking why not just build a tube amp.  Heres the problem.  The only kits I can find are Dynakit, and one from the Tube Store.  Too expensive or too small.  I cannot find any info or schematics to build your own.  I bid on a Fisher 500 tube amp that needed work but didn't win the auction.  The question is would you buy and repair a tube amp or build your own?
Re: Need advice on Stereo Amp to play vinyl
« Reply #1 on: September 30, 2015, 05:48:43 pm »
Possibilities are endless & mind boggling.  Google Williamson amplifier.  Can't go wrong with a Dynakit.  Numerous old schematics to copy like from Heathkit.  I personally like to rebuild
Offline p2pAmps
    • p2pAmps
« Reply #2 on: September 30, 2015, 06:18:12 pm »
There is always a tube McIntosh
Everything Affects Everything
Offline Jack_Hester
  • Greybeard
« Reply #3 on: September 30, 2015, 06:23:48 pm »
Get yourself one of these:
http://www.ebay.com/itm/Magnavox-Stereo-175-67-Tube-Amp-Amplifier-6V6-12AX7-5U4GB-P-P-Push-Pull-Works-/181887696552?hash=item2a5959fea8
And, find a nice Heathkit or Realistic stereo pre-amp to go with it.  I have a Mag 175 and a Realistic pre-amp, both I've tested and am pleased with the results.  I have a Technics SL-1800 direct-drive turntable for the front end.  All working, but not assembled into a finished stereo.  A friend pointed me to a nice set of table-top speakers that really complement these components.  I'll have to get the model number for them tomorrow.
All this would make a great project for your home stereo.
Jack
"We sleep safe in our beds
                                                   ---George Orwell
« Last Edit: September 30, 2015, 06:42:57 pm by mresistor »
Offline p2pAmps
    • p2pAmps
« Reply #5 on: September 30, 2015, 06:42:12 pm »
« Last Edit: September 30, 2015, 06:46:33 pm by mresistor »
Offline x44d80
« Reply #7 on: October 11, 2015, 08:47:36 am »
« Reply #8 on: October 11, 2015, 10:03:16 am »
I don't recommend that specific unit because it does not have a power supply. The power supply is located on another unit. However, that same seller has other Rockola amps for the same price that do include a built in power supply.
Something to consider... These old juke box amps 'may' be designed for a ceramic phono cartridge. If so, you will need an external preamp to use a magnetic cartridge.
Offline x44d80
« Reply #9 on: October 11, 2015, 12:37:49 pm »
Good advice.  Thanks so much!
