September 16, 2026, 03:56:25 am
Hoffman Amps Forum image Author Topic: Tweed Overdrive Special - V2b-6 plate resistor  (Read 6842 times)
Offline adamG
« on: October 09, 2015, 04:59:59 am »
Tubenit,
Sorry for direct question to you, but I've got started my build of TOS as initial circut http://el34world.com/Forum/index.php?topic=9636.0 ,and I need to ask for V2b-6 plate resistor value.
Is it 180k or 120k that was indicated in this topic http://el34world.com/Forum/index.php?topic=9726.0 ?
Thank you in advance.
Regards,
Adam
Offline darkbluemurder
Re: Tweed Overdrive Special - V2b-6 plate resistor
« Reply #1 on: October 20, 2015, 05:57:34 am »
Hi Adam,
I am not Tubenit but the resistor should be 180k.
I will be starting my build soon.
Cheers Stephan
« Reply #2 on: October 20, 2015, 12:21:35 pm »
180k for V2b (V2-6) is correct.
Tubenit
Offline adamG
« Reply #3 on: October 21, 2015, 03:56:56 am »
Thank you!;)
Offline adamG
« Reply #4 on: October 21, 2015, 04:00:34 am »
Are you going to present sound clips?
To me, clips are rather difficult.On that field, I am a kind of lazy man;)
Which circuit are you following?
Regards,
Adam
« Reply #5 on: October 22, 2015, 02:37:41 am »
I am not set up for sound clips.
I have not finally decided whether I follow the TOS circuit or whether I use a Bluesmaster tone stack for the clean mode.
Cheers Stephan
