September 16, 2026, 03:57:43 am
Hoffman Amps Forum image Author Topic: Bias pot for a Peavy classic 30 or delta blues amp  (Read 4457 times)
Offline pbman1953
« on: October 19, 2015, 09:16:04 pm »
Has anyone done one before?
Easy install?
Worth it? Or just buy the right tube set
Re: Bias pot for a Peavy classic 30 or delta blues amp
« Reply #1 on: October 19, 2015, 09:29:20 pm »
Both look straightforward on paper. Just replace R63 with a 50K pot and replace R64 with a 22K resistor.
Offline pbman1953
« Reply #2 on: October 20, 2015, 06:53:35 am »
Is it worth it to do it?
« Reply #3 on: October 20, 2015, 08:26:04 am »
That depends on how accessible R63 and R64 are. They are likely mounted on a board. This style pot would probably fit the board nicely and be easy to adjust if the board is easily accessible. I used this Bourns trimmer on an old Harvard. Or you could always drill a hole in the chassis for a panel mount pot.
I think it's worthwhile to have a bias adjustment ***IF*** it's not too difficult to actually install the mod. I can't make that call on those Peavys without seeing them.
