September 17, 2026, 05:13:22 pm
Hoffman Amps Forum image Author Topic: New tone mod for the D'Mars ODS  (Read 5847 times)
« on: October 23, 2015, 09:32:15 pm »
The clean channel on the D'Mars is excellent to my ears and has a nice tight punchy bass.  While the OD channel has sounded good, it has sounded quite a bit thinner then the clean channel in the bass response.
The problem was increasing coupling caps or cathode caps in the OD section only added  distortion/mud and the clarity of the OD suffered.
So, today I thought that maybe if I bypassed the tone stack going into the OD that this would help the bass response be tighter and have more punch without the mud/distortion.
I tried using an .02, then .068 and settled on a .1.   I originally tried a 150k after the .02 but the drop in volume was too great.  I then tried a 56k but it did not have a "musical sweet spot" with that value.  Ultimately,  I settled on a .1 into a 10k resistor.  I did try it with NO resistor but thought the 10k actually added some smoothness.
What surprised me was how high a value coupling cap was needed for the bypass to get a similar bass response as the TMB tone stack??  The .1 value was much higher then I expected.   Having this .1 between the clean and the OD has allowed the OD to still have the clarity in the overdrive without turning to distortion or mush,  IMO.
Wished I had stumbled on this mod yrs ago!
I should add the TMB tone stack on the clean is pretty much a "set and forget" thing for me.  And the OD channel still has a hi-frequency cut that allows some tone shaping as well as the pickup switch and tone pot on the guitar.  So, no loss for me there.
« Last Edit: October 23, 2015, 09:34:50 pm by tubenit »
Re: New tone mod for the D'Mars ODS
« Reply #1 on: October 25, 2015, 10:41:24 am »
I am really loving this mod!  The OD sounds very transparent and MUCH thicker doing this!  This is definitely a "keeper" mod for me.
However, I noticed that the mid-boost feature in the tone stack doesn't work on OD now.  (actually really isn't needed with this mod)
So,  I pondered some different options.
1)  bypass tone stack mod
2)  switchable between bypass tone stack mod ................... or using tone stack
3)  using a pot to mix between bypass of tone stack or using tone stack
4)  using a relay switch to use the tone stack bypass as another boost feature for both clean or OD
« Reply #2 on: October 25, 2015, 01:35:35 pm »
Here is yet another option.
This allows the THICK OD tone and the normal  clean using the TMB tone stack.
OR .........................
A THICK OD and TMB tone stack combined on the OD ............................... and then just the TMB tone stack on the clean channel.
with respect, Tubenit
« Reply #3 on: October 26, 2015, 03:30:55 am »
Hi Tubenit thanks for sharing  :thumbsup:
it will be nice if you add schematics and explanations to the original D'Mars ODS tread
Offline guitardude57
« Reply #4 on: November 07, 2015, 11:19:20 pm »
There is an option to make a small daughter board
with trimpots and caps to create a tone circuit for just the OD.
Worked for Howard on the HRM...
« Last Edit: November 07, 2015, 11:23:33 pm by guitardude57 »
"I am never surprised, and always amazed".
Mike
« Reply #5 on: November 07, 2015, 11:25:24 pm »
Here is an example of one...
Mike
« Reply #6 on: November 08, 2015, 06:14:11 am »
IIRC, the original HRM was off the plate of the second gain stage of the OD of the D-HRM.   So, I am presuming on the D'Mars that you're thinking of using this off the cathode follower behind the 5879 pentode?
IF so, that sounds like a good idea.  Thanks!
Offline JJones
« Reply #7 on: December 20, 2015, 09:02:46 pm »
Tubenit, I'm considering building one.  After a bit of searching, I can't seem to find what size the chassis is.  Any insight?
Thanks for the concepts!
« Reply #8 on: December 21, 2015, 06:08:56 am »
20" X 8" X 2.5" with outward edges to attach.
There is a current chassis photo, updated information,  schematic and layout in SCH form here in reply #1:
http://el34world.com/Forum/index.php?topic=17305.0
Not a particularly neat wiring job but the amp is very very quiet at idle even when the pot settings have the volume cranked up
« Last Edit: December 21, 2015, 06:33:16 am by tubenit »
Offline JJones
« Reply #9 on: December 21, 2015, 07:21:41 am »
Looks neater than my work...  :worthy1:
Thanks for all your help!
« Reply #10 on: December 21, 2015, 09:28:24 am »
Ahem......  I believe it's time for another recording session?
Jim :icon_biggrin:
