August 29, 2026, 02:05:38 pm
Hoffman Amps Forum image Author Topic: AB763 Twin build  (Read 3911 times)
Offline willhugh
AB763 Twin build
« on: November 05, 2015, 04:45:18 pm »
I was curious if I need 6 diodes for the rectifier or can i use just two.
Thanks Will
Re: AB763 Twin build
« Reply #1 on: November 05, 2015, 05:42:02 pm »
If you use common/cheap 1N4007s then you really need four. If you have some 1 amp 1500PIV diodes then two will be fine.
