September 08, 2026, 12:17:55 pm
Hoffman Amps Forum image Author Topic: Allied 365 / Pioneer SX1000TX  (Read 6670 times)
« on: November 17, 2015, 09:07:53 am »
I have an Allied 365 (1968-1969) receiver which was made in Japan and is the same as the Pioneer SX1000TX (Schematic Attached) I have used for years but have noticed is beginning to request some service.  Everything on the receiver and inputs especially the phono stage(s) are working great.  I have a main filter cap just beginning to leak.
My question is since I will be replacing the electrolytics and doing a general service cleanup, is there any other things that would be good to upgrade, replace?
Re: Allied 365 / Pioneer SX1000TX
« Reply #1 on: November 18, 2015, 08:18:26 am »
I'm of the adage "leave sleeping dogs lay".  most of the schematic is "black-boxed" if they are sealed metal units then leave 'em.  good visual will usually give you an indication, browned areas, dust/gunk etc.  If the transistors are soldered leave em, if they are screwed to sockets and the thermal grease is cracked n dry - maybe, same with mica isolators.
Good bath in contact cleaner and you're probably good.
