August 29, 2026, 02:04:57 pm
Hoffman Amps Forum image Author Topic: Looking to build a PSE 10 watt. Suggestions on circuit and OT?  (Read 4734 times)
Offline hesamadman
« on: January 01, 2016, 02:55:52 pm »
I want to build a PSE 10 watt combo. I have a 5 watt. Would like to up it a little. Looking for schematic and OT suggestion. I have been using the Gretsch 6151 schematic for my 5 watt.
This the only OT I found. Hoping someone can suggest some others.
http://www.angela.com/fendersingleended10wattoutputtransformer.aspx
Re: Looking to build a PSE 10 watt. Suggestions on circuit and OT?
« Reply #1 on: January 01, 2016, 03:54:17 pm »
thalking about the OT ....
Which is your choice about power tube or tubes ?
About the project this is only one idea
« Last Edit: January 01, 2016, 04:01:17 pm by kagliostro »
« Reply #2 on: January 01, 2016, 04:05:30 pm »
Here's one I build awhile ago, went over pretty well with my Son and his guitar friends
« Reply #3 on: January 01, 2016, 04:51:01 pm »
Another option is Gibsons GA-8 6V6, pse.  I built this also, my *note* taking skill were pretty bad so I don't have OT data I used.  Also a went over well with the guitar guys
« Reply #4 on: January 01, 2016, 06:39:22 pm »
Note that double-Watts is NOT twice as loud. You may be disappointed. Twice-as-loud suggests 20W-50W, but roadies hate hi-power SE amps.
3W-25W  http://www.hammondmfg.com/125SE.htm
30W or 75W  http://www.hammondmfg.com/1627.htm  ($$$)
Same plan, only raise the main B+ voltage and current 40% and use a power bottle twice the size of a 6V6 (such as 6L6GC, KT88, EL34...).
Or keep the same B+, double the available current, half the load, and parallel two 6V6. (Use grid-stoppers and add 100r in each plate and screen lead.)
Fender AA-Champ is another fine base if you like knobs.
