September 12, 2026, 05:05:08 pm
Hoffman Amps Forum image Author Topic: 12.6v Heater Wiring  (Read 13481 times)
12.6v Heater Wiring
« on: January 22, 2016, 05:16:03 am »
Hi guys, got a tricky one.
I have a PT that only has 12.6v CT @ 4A (not 2x6.3v taps)as its heater supply.
The amplifier that had this PT was a 100w PA using 6550 tubes.
As per the schematic of the amp, the tubes were arranged as per my top drawing. To me it seemed lopsided as the tubes current on either side of ground are not equal,but this is how the amp was wired and the total current is more than 4A.
I want to reuse this PT in another build and I took a stab on how it could be laid out. Thanks
Re: 12.6v Heater Wiring
« Reply #1 on: January 22, 2016, 08:56:09 am »
I don't think the unbalanced current draw matters.  It's as if you had 2 separate filament trannies, ea capable of 6.3-0 @ 4A.  Here, the secondaries "happen to" share the same primary coil, and are wound out of phase so that their 0's are conveniently located in the middle, creating 6.3-0-6.3 @ 4A. So the 2 secondaries don't know or care if they have balanced current draw.  (Maybe the primary will begin to care at some point, but let's assume the designers did their job well enough.)  Current in excess of 4A will drop voltage, but as long as 5V remain, the tubes will be happy.
My question: is it noisy?  If the heaters are quiet and free from hum, then the stock circuit is OK.  But in some old PA amps, some level of hum may have been tolerated.  The one-sided ground scheme at ea tube negates the benefit of humbucking by using twisted pairs of filament wires.  Not so much an issue with PP power tubes, because the PP arrangement is noise & humbucking anyway.  It might be an issue with other tubes.  OTOH, twisting filament wiring is considered over-rated by some; and many quality vintage amps did not do so with no ill affects.
If you need or want to use twisted pairs to buck hum, there's another alternative:  Make a series-pair of 2X 6.3V tubes. This sums to 12.6V for ea series pair-- BUT the filament current draw must be the same for ea of the two tubes in a series pair.  Wire the series-pairs in 2X parallel strings from the tranny.  Use a pair of ground reference resistors for each string.
If there's an odd tube with no mate for a series pair it can be left one-side grounded.  For lowest hum, do this with a tube late in the chain and/or with a low noise tube (not an EF-86 if possible).  Any heater hum that originates early will be re-amplified in later gain stages.
« Reply #2 on: January 22, 2016, 08:59:42 am »
JJ has a good explanation. I looked at your schematic, and I'm curious about the 6V6 at the end of the chain. AFAIK, that should be before the preamp tubes because of current draw & noise.
« Reply #3 on: January 22, 2016, 02:23:53 pm »
Thanks guys, This is the amp I'm looking at cloning http://el34world.com/Forum/index.php?topic=19585.0
And this is the PA that the transformers came out of.
« Reply #4 on: January 22, 2016, 02:33:07 pm »
BTW: for more on filament wiring schemes, see Hotblue's Reply in this thread:  http://el34world.com/Forum/index.php?topic=19701.msg205363#new
« Reply #5 on: January 22, 2016, 02:54:38 pm »
Thanks JJ, I have been pretty lucky with beating the hum from heater wires, I usually tuck then into the corner of the chassis when the tubes are lined along the back of the chassis.
« Reply #6 on: January 22, 2016, 03:25:18 pm »
see attached.
« Reply #7 on: January 22, 2016, 04:24:17 pm »
OOoooo, Nice one pete. I was wondering if I could go down that track. :icon_biggrin:
« Reply #8 on: January 22, 2016, 04:57:52 pm »
z-y load: 1.6A+1.6A+0.6A= 3.8A
3.8A is less than 4A, OK
x-y load: 0.3A+0.6A= 0.9A
0.9A is less than 4A, OK
with "PA Head":
x-y load: 0.3A+0.6A+0.3A+0.3A+0.3A= 1.8A
1.8A is less than 4A, OK
I say each winding is under-loaded. One only slightly, the other is loafing.
I say you could add a half-dozen more small bottles and still be cool.
The grounded winding IS awkward for guitar-amp level circuits. It is a bit odd they did that for microphone inputs. It may have been "Gee, we got a hundreds Watts!!" rather than "We have pure-pure sound." (100W is poop-yer-pants big for 1960.)
« Reply #9 on: January 22, 2016, 11:44:29 pm »
Hi guys, This is the full article.
« Reply #10 on: February 15, 2016, 03:47:07 am »
Hi guys, I'll try this arrangement.
Offline trobbins
    • Tim's projects and info
« Reply #11 on: February 16, 2016, 01:01:52 am »
I think the intent is that they wanted to leave one 6.3V supply available for external gear - so to allow that supply to have the max capability, they internally maxed the other 6.3V.
The EF86 was probably going to give good enough hum because the input grid is pretty well shielded from heater pins and internals, especially if using a spigoted socket, and placing the transformers a fair distance away.
« Reply #12 on: February 16, 2016, 11:45:04 pm »
NZ amp makers, Jansen, used to do their amps with 12.6Vac wiring. Reduces current draw for the whole heater winding. Each pair of 6.3VAC output tube filaments in series only draws what one output tube heater alone would otherwise draw (and of course the pre-amp bottles' heater current is half of what a 6.3VAC scheme is). I had occasion to rebuild one from scratch just over a year ago. I put a 100R wire-wound humdinger pot in it.
« Reply #13 on: February 17, 2016, 03:29:25 am »
I'll try this arrangement (take 2)
« Reply #14 on: February 17, 2016, 07:26:51 am »
Good thinking!
« Reply #15 on: February 18, 2016, 02:06:15 am »
What about putting the pairs of 6550s together and the pair of 6SK7s together and the 6V6 with the EF86, and run the 12AX7s as 12V each on pins 4 and 5?
« Reply #16 on: February 18, 2016, 04:48:13 am »
That was Dummyloads idea as well. Ok that seems to be a better way to go, thanks guys.
« Reply #17 on: February 20, 2016, 11:45:48 pm »
Hi guys, I'm having a bit of battle with doing the circuit as per DL's schem.
I checked the voltage across the winding and a nice 15v is present.
Wiring as per schem getting required volts across pins 4,5 on the 9 pin sockets and the same for the octals, at this stage no 100ohm CT resistors added.
When the CT resistors added I do not get a voltage reading across the CT resistors.
I put in a couple of valves and the heaters didn't glow.
I can't see what I missed. Thanks
« Reply #18 on: February 21, 2016, 04:25:51 pm »
Are you sure you have not  connected the two 6.3v windings counterphase ?
« Reply #19 on: February 21, 2016, 08:12:28 pm »
that plan should work unless something is mis-wired. clock-bottom/counter-top?
« Reply #20 on: February 22, 2016, 01:59:29 am »
Hey Pete,
 clock-bottom/counter-top? not sure what that means.
Anyway.............
MY BAD, it seems that the dope putting this amp together has over looked a simple task.
When removing the PT from the original chassis I cut the CT (four strands of wire) off a solder pad on the chassis and when tiding up the unused wires with heatsrink (CT included) I forgot to solder the strands together. WHAT A DORK  :BangHead:
With all valves in a great 12.7v across the two rails. Thanks
« Reply #21 on: February 22, 2016, 02:42:07 am »
pin orientation on the socket: was thinking perhaps that you may have mis-wired.  :icon_biggrin:
bottom view - clockwise. clock-bottom
top view - counterclockwise. counter-top.
« Reply #22 on: February 22, 2016, 03:03:47 am »
 :icon_biggrin:
« Reply #23 on: February 23, 2016, 02:33:14 am »
Hi guys, Seems that we are not totally done yet.
One of the local guys has brought up a good point.
The heater/cathode has a max of 200v and the voltages that were supplied to me has the cathode seeing approx. 300v it was suggested that a floating isolated supply be added.
http://www.altronics.com.au/p/m1000-600-ohm-600-ohm-telephone-isolation-transformer/
Could it be something like this  :dontknow:
« Reply #24 on: February 23, 2016, 02:58:18 am »
that's not going to work.
use a separate 6.3VCT 500mA filament transformer & lift the CT off ground about 100V with a divider network hanging off the B+ rail. or just leave it floating.
« Reply #25 on: February 23, 2016, 03:12:47 am »
Thanks Pete, so what do we do with the EF86??
« Reply #26 on: February 23, 2016, 03:29:01 am »
put a resistor under it. 6.3V/200mA = 31.5R use a 33R3W part: a 2W will work but will get warm...
what were you going to use for the coupling transformer in that drawing? whatever it is, it needs to be 2:1 for best results.
« Reply #27 on: February 24, 2016, 01:37:00 am »
Would adding a fuse to the circuit be needed.
Offline trobbins
« Reply #28 on: February 24, 2016, 02:02:20 am »
No Tim - it would be unlikely to blow, and given the circuit is very simple, it would be highly reliable once you've checked it.  Like a directly heated rectifier heater - it is hazardous.
That heater should be connected to the 6V6 cathode - don't leave heaters floating.
« Reply #29 on: February 25, 2016, 11:59:25 pm »
Like this
Offline trobbins
« Reply #30 on: February 26, 2016, 01:45:51 am »
 :smiley:
