September 18, 2026, 01:08:00 am
Hoffman Amps Forum image Author Topic: 6L6 single ended in simultaneous pentode/triode?¿  (Read 4079 times)
Offline chocopower
« on: January 22, 2016, 12:34:10 pm »
I got this 60´s amp.
http://www.doctsf.com/grandlivre/fiche.php?f_ref=29394&ori=ps
My amp has some different stuff on it.
One i dont understand is that it have a B+ node for screens but there are too, a 100k resistor (with a 4700pf in parallel) between plate and screen.
.- Is this a kind of mix between triode and pentode operation?
.- It´s safe to remove it?
Attached the schemo with the resistor.
Thanks in advance.
« Last Edit: January 22, 2016, 01:50:20 pm by chocopower »
David
Re: 6L6 single ended in simultaneous pentode/triode?¿
« Reply #1 on: January 22, 2016, 03:17:35 pm »
No, because C14 absorbs all audio signal at screen.
The 4,700pFd is in-effect across the OT primary. A cap across OT is VERY common to reduce high frequency ringing in low-price OTs and possible supersonic instability. In this case it probably cuts response above 8KHz. For guitar I would leave it there. It does no harm and may be unstable without it.
The 100K is a complete mystery to me.
Offline chocopower
« Reply #2 on: January 22, 2016, 03:43:39 pm »
Ok, thanks.
I´ll try to find some informattion for the 100k resistor.
Both seems original.
So... "ain't broken, don't fix it"
David
