September 16, 2026, 01:07:08 am
Hoffman Amps Forum image Author Topic: Older Weber blue capcans  (Read 4101 times)
Offline crashtm1
« on: January 29, 2016, 07:40:29 am »
Not sure what happened. I see that Weber has a different style now.
 One, maybe 2 of mine dropped out of their cans, then shorted out on other wires.
Toasted all 4 power tubes. 😢😢😢😢
Either they dropped out or the amp got slammed or dropped hard.
Anyone had this problem?
Thanks!✌🏻️✌🏻✌🏻✌🏻
Offline MFowler
Re: Older Weber blue capcans
« Reply #1 on: January 29, 2016, 09:05:03 am »
Your saying the Weber cap can fell apart, center of the can cap slipped out of the can?
Never heard of that but anything is possible with cheap caps.
Mark
Offline crashtm1
« Reply #2 on: January 29, 2016, 08:22:28 pm »
I don't know if I would consider $28 a piece cheap, but?? I'll post a pic after I pull them. Should be able to tell if they exploded.
« Reply #3 on: January 31, 2016, 05:25:24 pm »
Not sure what you are saying happened
Can you elaborate with pics or more detailed text?
Offline SoundmasterG
« Reply #4 on: February 03, 2016, 12:44:29 am »
The way that Weber made their blue cap cans, they aren't very sturdy. The copper tube is glued from the end of the tube to a forbon base with CA glue. I've broken some bases off the cans in the past just installing the can on the amp and had to re-glue them. They are handy in that you can get custom cans with different values and even separate grounds, but they need to be made better.
Greg
