September 16, 2026, 05:22:10 am
Hoffman Amps Forum image Author Topic: The Playmaster 102 with 6BE6 Penta-Grid Vibrato  (Read 7895 times)
Offline jazbo8
« on: January 29, 2016, 10:10:21 am »
Original title: What Happened to ozvalveamp.org?
I think it has gone offline... does anyone know what happened to it? Anyway, I am looking for the article on Playmaster 102, if anyone has a copy, please send me/upload a copy.
TIA,
jaz
« Last Edit: January 30, 2016, 02:34:50 am by jazbo8 »
Re: What happened to ozvalveamp.org?
« Reply #2 on: January 29, 2016, 10:45:46 am »
Aww crap, can't get to the scanned article as it was not archived.  Sorry!
Offline jazbo8
« Reply #3 on: January 29, 2016, 10:57:08 am »
I know, so much for archiving... :BangHead:
Online kagliostro
Re: The Playmaster 102 with 6BE6 Penta-Grid Vibrato
« Reply #4 on: January 29, 2016, 11:06:36 am »
Our friend Roly has some health problems
some time ago at AGGH (www.guitargear.net.au) someone was offering to continue his effort on www.ozvalveamps.org
but I don't know the actual situation
About the Playmaster 102 don't worry
Radio Television and Hobbies - October 1962 - Vol 24 - No. 7
http://www.mediafire.com/view/niw38zigdgtc23r/Playmaster_102.pdf
Schematic
« Last Edit: January 30, 2016, 02:36:51 am by kagliostro »
Offline jazbo8
« Reply #5 on: January 29, 2016, 11:18:55 am »
Great! I knew someone must have download it at one point, too bad about ozvalveamp though, it had a lot of interesting information on Aussie amps.
Online kagliostro
« Reply #6 on: January 29, 2016, 11:53:52 am »
To which part of the 102 are you interested ?
« Last Edit: January 30, 2016, 02:37:16 am by kagliostro »
Offline jazbo8
« Reply #7 on: January 29, 2016, 01:35:24 pm »
Mainly the use of unusual tube such as the 6BE6 and the screen-grid-modulation of the vibrato circuit - you don't see those everyday...
« Reply #8 on: January 29, 2016, 02:39:46 pm »
Hi guys, Not sure what is happening with the site  :dontknow:
Jaz, Here is another Aussie amp that has a similar circuit.
http://el34world.com/Forum/index.php?topic=19585.0
Online kagliostro
« Reply #9 on: January 29, 2016, 04:12:14 pm »
Ciao TIMBO
Yes, also that is an interesting schematic  :thumbsup:
the ef86 tube is used in a similar way
« Last Edit: January 30, 2016, 02:37:31 am by kagliostro »
Offline jazbo8
« Reply #10 on: January 30, 2016, 12:18:13 am »
In the above Maxim schematic, the pentode drivers (6SK7's) appear to be drawn incorrectly - the suppressor and screen grids are reversed.
« Last Edit: January 30, 2016, 02:39:14 am by jazbo8 »
« Reply #11 on: January 30, 2016, 01:43:00 am »
That's not "screen" in a penta-grid.
G1 is oscillator grid, linear. G2 is osc plate. G3 is Signal Grid, remote-cutoff. G4 is amplifier "G2", accelerator screen. G2 and G4 are tied together to like +100V. G5 is suppressor,  masks the tetrode kink.
It seems logical to feed guitar to G3 because it does gain control. But the guitar would change its own gain, second harmonic distortion. That is acceptable in AM radio reception because the modulation is both-sides and is recovered in each narrow-tuned filter circuit. These techniques fail for baseband audio.
Here the guitar goes to G1, G3 only does wobble. This gives gain control without (as much) distortion.
In any case, the final plate current changes a LOT, which means the DC level at the plate changes a LOT, at a slightly sub-audio rate. This would gob-smack the next amplifier stages. So there's heavy R-C filtering to reduce sub-audio signal.
Offline jazbo8
« Reply #12 on: January 30, 2016, 01:49:32 am »
My bad, I didn't even see that the 6BE6 was not a regular pentode, nor bothered to look up the datasheet... sigh...
« Last Edit: January 30, 2016, 02:36:49 am by jazbo8 »
Online kagliostro
« Reply #13 on: January 30, 2016, 02:21:31 am »
PRR is this to say that it is an interesting way to have a vibrato on the signal ?
p.s.: Jazbo8, may be that if you correct the title of the thread (Playmaster 102 and the 6BE6 vibrato) a larger number of forumer is enticed to read it
« Last Edit: January 30, 2016, 02:37:53 am by kagliostro »
Offline trobbins
    • Tim's projects and info
« Reply #14 on: January 30, 2016, 03:23:47 pm »
You probably found this article in your travels? It was on retrovox at one stage.
http://dalmura.com.au/projects/6BE6audi.pdf
Offline jazbo8
« Reply #15 on: January 30, 2016, 10:45:10 pm »
No I must have missed it, thanks for sharing it.
