September 18, 2026, 08:55:23 pm
Hoffman Amps Forum image Author Topic: Hum in POWER section?  (Read 4756 times)
Offline jbefumo
  • Technical competence is the servant of creativity
« on: February 20, 2016, 10:55:05 am »
Just gutted and rebuilt my KT-120 based single-ended amp in order to implement a refined board layout, shorter wire runs, etc.  It was really quiet before, but now it has a loud hum, and the output is low.  After some basic troubleshooting, I pulled the power tube, and ran a ground and signal jumper from pin 5 of the power tube socket to a practice amp, and ... no hum.  Tried a different output tube and the hum is back. Checked the plate, G2, and cathode voltages and all are where they should be. Before I start shooting in the dark, any suggestions? (it's cathode biased, btw.) Thanks.
Joe
Technical competence is the servant of creativity.
Re: Hum in POWER section?
« Reply #1 on: February 20, 2016, 11:23:43 am »
gutted and rebuilt
did you move the iron?
sounds like you have induced hum into the OT?  Maybe from new wire layout?
maybe try swapping for test the primary OT leads?
try putting a nice iron bar tween PT and OT, make any dif?
Offline jbefumo
« Reply #2 on: February 20, 2016, 12:10:26 pm »
Nope -- didn't touch the iron or the power supply.  Will double check the leads & iron bar trick (never heard that one before.) I'm sure it's something stupid obvious ...
gutted and rebuilt
