September 12, 2026, 12:03:05 pm
Hoffman Amps Forum image Author Topic: Rebuilt Little Vox  (Read 5250 times)
Offline rosincore
  • Unplug It First
Rebuilt Little Vox
« on: February 21, 2016, 07:11:21 am »
A number of years ago this little Vox hybrid amp found it way onto the bench. It was dead except for the lamp. I am a tube guy and my knowledge of transistor circuits is nil so I deferred opening this up. The the owner asks if I can make an ALL tube amp out of it---that I can do. So I gutted it and rebuilt it. I went with a single ended design which I believe now that I look at it looks like a Champ circuit. It is a very simple build as you can see but boy does it ever sound good. It has been used to record numerous times. Just a tiny bit of single ended hum, barely noticeable, but it sure does work nice.
"Lets have a look at the schematic a moment"....
Offline rosincore
  • Unplug It First
Re: Rebuilt Little Vox
« Reply #1 on: February 21, 2016, 07:12:35 am »
A few more photos of the little Vox rebuild.
« Reply #2 on: February 21, 2016, 09:35:57 am »
Nice job. I like projects like this.  Which Vox model is that cab? I stuffed a 18W Plexi into a little Pathfinder cab and just recently put my L'il Maggie in a Pathfinder cab too.
Offline rosincore
  • Unplug It First
« Reply #3 on: February 21, 2016, 09:56:19 am »
I believe it was something like model 15 R or such. It had one 12 AX7 in it for preamp and from there into solid state, which is a state I don't visit-lol. I stay in the tube nation.
« Reply #4 on: February 21, 2016, 10:08:17 am »
That sounds like a Cambridge. That's a cab I've been interested in also. Would you mind making a couple measurements? I'd like to know the length and width of the upper back panel. Also the length and width of the cutout for the controls on the top of the amp. THX
Offline rosincore
  • Unplug It First
« Reply #5 on: February 21, 2016, 10:25:59 am »
I will contact the owner and see if we can get those measurements for you.
Offline rosincore
  • Unplug It First
« Reply #6 on: February 27, 2016, 07:42:16 pm »
I was able to stop and get some more photos to share as well as those dimensions.
