September 08, 2026, 01:11:00 pm
Hoffman Amps Forum image Author Topic: reference schematic needed, parallel SE 5881 build  (Read 7833 times)
Offline centervolume
« on: February 27, 2016, 12:01:29 am »
Greetings all-
I'm trying to finish up a switchable single 5881 to parallel single ended 2x5881 cathode bias little number). Essentially the schematic I designed was tweed twin/bassman front end (treb., mid, bass tone controls) and a gibson GA-8 style power section/back end all in a hybrid tweed vibrolux/harvard sized package.
She is suffering from some issues mostly in the power section and I was wondering if there was a good reference schematic for an single ended parallel 5881 or 6L6 I could refer to trying to control high gain squeal and make sure I have enough AC filtering.
Similar designs I have heard referenced are the southbay captain crunch and brian schmittling's SSEL 30watt.
thanks in advance
Attila
  • Guest
Re: reference schematic needed, parallel SE 5881 build
« Reply #1 on: January 03, 2017, 02:27:37 pm »
This might help if you've not found a solution yet
