September 16, 2026, 05:06:04 am
Hoffman Amps Forum image Author Topic: Speed pot in PR  (Read 4071 times)
Offline Shack
Speed pot in PR
« on: March 02, 2016, 12:44:36 pm »
I wired up the 100k resistor to ground according to Dougs layout from the middle tab to ground. Then I noticed that the Fender layout ( and Dougs  PR ) had the resistor going from the middle and left tab to ground.
Is there a difference between the 2 wirings?
New build problems? Click here.
Re: Speed pot in PR
« Reply #1 on: March 02, 2016, 01:16:19 pm »
No difference as far as normal operation goes. But if the pot wiper fails, the pot that has the outer lug jumpered to the wiper will continue to operate at it's slowest speed, but the pot with one outer lug not connected will cause the trem to shut down. Either way you'll know something is wrong. I always connect the outer lug to the wiper when using any pot as a simple variable resistor.
Offline Shack
Re: Speed pot in PR
« Reply #2 on: March 02, 2016, 02:41:25 pm »
oh ok.......thank you.
I learn something here every day
