August 29, 2026, 02:05:22 pm
Hoffman Amps Forum image Author Topic: WY3GT Copper Cap - Which resistor is inside ?  (Read 4235 times)
« on: March 25, 2016, 03:09:27 pm »
The spech of the Weber WY3GT Copper Cap say it gives the same voltage drop of a 5Y3GT, 50v @ 125mA
As known on the Weber Copper Caps there are diodes and drop resistor/s
Is correct to think a 400R (10W) resistor after a pair of diodes can be used ? (5Y3GT drops 50v @ 125mA) ?
I've a 325v-0-325v PT that has only a 6.3v winding (OK, 7v unloaded) and would like to know if I can use it in something like a 5F1
BTW which is the weight of a 5F1 PT ?
Grazie
Re: WY3GT Copper Cap - Which resistor is inside ?
« Reply #1 on: March 25, 2016, 04:59:56 pm »
yes
Doug probably has that info for his transformer specs.
« Reply #2 on: March 25, 2016, 05:19:43 pm »
Thanks Steve
