August 29, 2026, 02:05:50 pm
Hoffman Amps Forum image Author Topic: transformer position and oscillation  (Read 5886 times)
Offline alange5
« on: April 18, 2016, 09:22:15 am »
hello all.
I built a 5F1 a while ago and it's started having an oscillation problem.  Using a chopstick, I can get the oscillation to stop by moving around the blue OT wire (to 6V6 plate), but I can't get it to stop completely.  For instance, if I have oscillation with the volume dimed, I'll move the wire and it'll stop - then it might show up with the volume up halfway.  Position of the tone control also seems to trigger the oscillation in various positions.  I unbolted the OT (Classictone) and found that changing the physical position of the OT can also induce/reduce oscillation and overall noise.  The problem is I built the amp in an old radio chassis mounted in a tiny cabinet, and there's not much space to move things around without interfering with the speaker magnet.
My question:  Is the OT no good? Is it common for its physical position to induce noise? Or is this indicative of a larger internal problem?  My voltages are all good, and the amp was used regularly for about a year before the oscillation started.
Re: transformer position and oscillation
« Reply #1 on: April 18, 2016, 09:42:35 am »
Does the oscillation go away if you break the NFB loop by disconnecting the 22K from the speaker jack?
Show us some pics.
Offline alange5
« Reply #2 on: April 18, 2016, 10:46:29 am »
Show us some pics.
Nope, it's present with or without NFB, and OT primaries are oriented correctly.  I'll take some pics when I get home this evening.
« Reply #3 on: April 18, 2016, 11:09:23 am »
Maybe your preamp tube went microphonic.
Small chassis > induce vibration in tube.
Got a swapper tube?
Offline alange5
« Reply #4 on: April 18, 2016, 12:05:49 pm »
I just put a 1.5k resistor before the 6V6 grid.  Now I only get oscillation with the volume maxed and the tone control in a very specific spot, regardless of OT orientation.  For the heck of it, I installed a 12AY7 in V1 and it's gone completely.  Later, I'll try some other 12AX7's.
« Reply #5 on: April 18, 2016, 04:10:15 pm »
The plate-OT lead must be short and FAR away from low-level stages (including tone controls).
If your chassis can't do that, you have a problem.
