August 29, 2026, 02:05:03 pm
Hoffman Amps Forum image Author Topic: 18 watt Hoffman Stout into 30 watt?  (Read 5153 times)
Offline Oddvar
« on: April 29, 2016, 11:56:56 am »
HI.
Is there a possibility of making the Hoffman Stout 18 watter into 25-30 watt?
Re: 18 watt Hoffman Stout into 30 watt?
« Reply #1 on: April 29, 2016, 12:29:04 pm »
Yes. Just add two more EL84s, and get a PT and OT that are designed for an AC-30. Use different cathode resistors for the EL84s. Basically just copy the AC-30 output stage.
Offline Oddvar
« Reply #2 on: April 30, 2016, 03:28:03 am »
Thanks again, is there a layout for that somewhere?
Offline basschops1528
  • --Amateur audio electronics guy--
« Reply #3 on: April 30, 2016, 06:15:25 am »
This is the AC30 layout here. Check out the power amp section on the right as Sluckey mentioned.
« Last Edit: April 30, 2016, 09:01:30 pm by basschops1528 »
Johnny D
« Reply #4 on: April 30, 2016, 08:49:31 am »
Just put the layouts for the Stout and AC-30 side by side. The changes you need to make should be obvious.
« Reply #5 on: April 30, 2016, 09:02:32 pm »
Oddvar, I attached the PDF for the Stout to my last post
Johnny D
