September 13, 2026, 04:52:30 pm
Hoffman Amps Forum image Author Topic: Removing the tremolo circuit from a Deluxe Reverb  (Read 8563 times)
Offline fingersoccer
« on: May 17, 2016, 03:09:57 pm »
I'm going to build a Deluxe Reverb from scratch, but I'd like to leave out the tremolo. The tremolo circuit is easy enough to identify and pull out of the schematic, but I want to make sure I'm not accidentally removing some crucial bit of the bias circuit in the process. I looked at the Blackface Bassman schematic (since it doesn't have tremolo) and came up with what you see here. It looks right to me, but I could use some wise eyes on this to double check.
I found a useful thread on the (DIY Audio Forum), but the images links are broken, rendering it a bit less than helpful.
And evermore in the world is this marvelous balance of beauty and disgust, magnificence and rats.
Re: Removing the tremolo circuit from a Deluxe Reverb
« Reply #1 on: May 17, 2016, 04:06:33 pm »
Looks good. Your R20 should be 47Ω for a Deluxe Reverb using an 8Ω speaker. R40 and R41 should be 10K.
« Last Edit: May 17, 2016, 06:04:56 pm by sluckey »
Offline Shack
« Reply #2 on: May 17, 2016, 04:52:53 pm »
How do you see that lol.....what would be the difference if the 100 ohm was left there?
New build problems? Click here.
« Reply #3 on: May 17, 2016, 05:15:01 pm »
I see it by looking at a DR AB763 schematic. NFB would be stronger using a 100Ω. Probably not hear much difference. That's just how Leo did it. All his AB763 amps that connected to an 8Ω speaker load used a 47Ω resistor in that position. The amps that had a 4Ω or 2Ω speaker load used a 100Ω resistor.
« Reply #4 on: May 17, 2016, 06:15:49 pm »
sluckey: The values for R20, R40, and R41 were all pulled from the Hoffman 1ch Deluxe Reverb build. Do you think those values should be replaced with the original Fender values?
« Reply #5 on: May 17, 2016, 06:17:41 pm »
Oh look, I found another thread with a very similar objective: http://el34world.com/Forum/index.php?topic=18882.0
« Reply #6 on: May 17, 2016, 06:36:25 pm »
That is Hoffman's AB763 amp. It's not specifically a Deluxe Reverb. Hoffman shows Deluxe Reverb specific values in this file...
     http://el34world.com/Hoffman/files/Hoffman_AB763_2.pdf
