August 29, 2026, 02:05:25 pm
Hoffman Amps Forum image Author Topic: Output 1:1 transformer - Which one for this circuit ?  (Read 4813 times)
« on: May 27, 2016, 09:46:25 am »
Offline labb
Re: Output 1:1 transformer - Which one for this circuit ?
« Reply #2 on: May 27, 2016, 03:34:21 pm »
Is "M1" = 100K?
If so, the transformer drive is up to 50K source. The transformer primary should be that much.
Especially for bass, since bass response is the first to go when source Z is higher than transformer design Z.
Why 1:1 ? There is a LOT of gain. And it says "DI" which usually goes to a *microphone* input. That pot should be 1V out typical, mike input needs a fraction of a volt. I'd think 5:1 or 10:1 step-down.
Possibly a tube mike input transformer used backward.
If there is any hope of a 15V-35V DC supply (heaters?) I would sneak in a chip to drive the long line.
« Reply #3 on: May 27, 2016, 04:05:16 pm »
Thanks labb & PRR
so ... this will do the job ?
10:1
http://www.tube-town.net/ttstore/Transformer/Matching-Transformer/Audio-transformer-10-1-for-microphone-signals-DIB-110::3812.html
« Last Edit: May 27, 2016, 04:10:30 pm by kagliostro »
