September 13, 2026, 12:15:27 pm
Hoffman Amps Forum image Author Topic: Weber OT gave in, new one swapable?  (Read 11152 times)
Offline Oddvar
« on: May 31, 2016, 01:50:38 pm »
Hi.  My Weber Ot just gave in and I blught a new one from Classic Tone, it's rated at 50/60 watts, and I was wondering if it is swapable without any modifications to the build?  The new one is 4/8/16 ohm, 4.2 k ohm,
Thanks.
Re: Weber OT gave in, new one swapable?
« Reply #1 on: May 31, 2016, 02:00:44 pm »
Which build? Which tubes? Got a schematic?
Offline Oddvar
« Reply #2 on: May 31, 2016, 03:49:01 pm »
« Reply #3 on: May 31, 2016, 05:22:22 pm »
The Weber WO22855 transformer only has a 2Ω speaker tap which is fine for the 5F6A amp. Your classic tone transformer does not have a 2Ω tap and is not a good replacement.
Offline Oddvar
« Reply #4 on: June 01, 2016, 02:01:30 am »
Hi and thanks again.
I bought the Classic Tone 40-18001 as a replacement for the Weber W041318.  The difference is the first one has 4.2k ohm primary and 4/8/16 ohm speaker output, the other has 6600 ohms and 8 ohm output.  I bought the Classi Tone from Ampparts Direct and Rick there said it was just to mount.  I did, and no sound whatsoever.
Offline Oddvar
« Reply #5 on: June 01, 2016, 02:57:11 am »
Now there is a indication of sound just as I plugin the speakerjack.  Makes me wonder if I have connected the speakerjacks wrong.  Anyone with an idea on the proper way to change from just 8 Ohms to 4/8/16 Ohms?
« Reply #6 on: June 01, 2016, 06:17:39 am »
Let's get some more info about what you have. A stock 5F6A has four 8Ω speakers wired in parallel for a total impedance of 2Ω. So you NEED a 2Ω OT. But sounds like you are using an 8Ω OT? What is your speaker configuration? Let's see some pics. Also show us some pics that clearly show how you connected your new OT to the speaker jacks.
Connecting speaker jacks should be a simple straightforward task. But if you don't understand it's also easy to get it wrong. Good pics will probably help us sort it out.
Offline Oddvar
« Reply #7 on: June 01, 2016, 07:58:33 am »
Hi Sluckey, again.
I had a Weber 8ohms Outputtransformer in the amp uptil now.  The amp was built after the Weber 5f6a layout.  I had a tech finish the final hoopups, with two jack outputs in 8 ohm each.  Suddenly the Weber OT stopped working and I have now bought a OT from Classic Tone, Amppartsdirect.  I want to have the possibility to use different ohming to go with different speakers.  Question is, since I was told this new OT could be used with the Weber 5f6a layout, I thought it was ok.  But I am a bit confused on how to connect the OT to the outputjacks, or what I need to connect it right.
Offline Oddvar
« Reply #8 on: June 01, 2016, 08:01:59 am »
 :laugh:
« Reply #9 on: June 01, 2016, 08:23:25 am »
I don't think the speaker jacks are wired correctly, but your pic is not clear enough to be sure. Post another pic that is zoomed in on just the 3 jacks. I need to be able lo clearly see the lugs on the jacks. Need sharp focus, high rez , big pic.
Offline Oddvar
« Reply #10 on: June 01, 2016, 08:39:13 am »
I must admit to be in a bit of dark here...
« Reply #11 on: June 01, 2016, 08:57:45 am »
320x281 ain't hi rez. Give me something big enough to see! Something like 2000x1200.
« Reply #12 on: June 01, 2016, 09:00:05 am »
You have a brown jumper between two jacks. Cut that out. Got sound now?
Offline Oddvar
« Reply #13 on: June 01, 2016, 09:23:48 am »
It's not possible to upload hi res here...
But how would one connect 4 / 8 / 16 ohm to outpujacks without a switch?
Offline Oddvar
« Reply #14 on: June 01, 2016, 09:24:51 am »
The brown lead is ground?
« Reply #15 on: June 01, 2016, 09:34:27 am »
Sure it is! Just keep the file size under 800KB.
The jack that has the orange wire connected does not appear to be a Switchcraft jack. Is that correct?
Offline Oddvar
« Reply #16 on: June 01, 2016, 09:39:38 am »
The orange to the left is a tip-ground-switch jack.
Offline Oddvar
« Reply #17 on: June 01, 2016, 09:51:14 am »
The lead coming from the board is going to the tip on the jack right.  The middle and right jack is grounded together, The top brown lead is going from ground rigt to the left jack ground.  The 4 ohm lead goes to the tip right jack, 8 ohm in the tip middle and the orange is going to the tip jack left.  The yellow lead is coming from the board, I am uncertain on where to put that?
Offline Oddvar
« Reply #18 on: June 01, 2016, 09:57:08 am »
 :worthy1:
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #19 on: June 01, 2016, 10:16:41 am »
If I'm seeing that right, you've got the common/ground wired to the tip and all the tips wired to that same connection which means all output goes to ground, so no, you'll not get any output that way.  The black wire 'should' be common/ground and connect to the ground of the jack (not tip). then you need to know which tap is which ohms and hook one of each up to a separate jack's tip connection.  (the long one with the curved part).  I believe you'll definitely want grounded switched jacks to remove noise as well because they ground out when not in use.  I think those looked like grounded ones.
Sluckey can confirm for sure though.
~Phil
Phil Davis
tUber Nerd =|D
« Reply #20 on: June 01, 2016, 10:18:58 am »
Much better. The yellow wire from the board will connect to the 4Ω jack. The jack on the left is not a Switchcraft and I can't identify the terminals without an ohm meter. For now, temporarily disconnect the brown and orange wire from the left jack. Do you get sound from the other two jacks now?
Rather than trying to figure out that oddball jack, I'm just gonna post a pic showing how you would wire the three jacks if they were all Switchcraft 12A jacks.
    • Daviszone
« Reply #21 on: June 01, 2016, 10:28:36 am »
Here's a great picture of a switchraft 12A showing it in a way that should make sense by color coding it:
http://gaussmarkov.net/images/plugs3.bmp
Basically red is tip, green is ground and the silver one is the 'switch' that you can ground if you need to (Which it should for multiple outputs or for input jacks, otherwise single outputs are Switchcraft 11 types)
And what Sluckey said ;)
~Phil
Phil Davis
tUber Nerd =|D
Offline Oddvar
« Reply #22 on: June 01, 2016, 11:30:47 am »
Hi Sluckey, did what you suggested, no sound still-
Offline Oddvar
« Reply #23 on: June 01, 2016, 11:44:08 am »
Funny thing is the only place that has a response is the presenceknob, it makes sound as I turn it?
Offline Oddvar
« Reply #24 on: June 01, 2016, 11:50:38 am »
This is the board in a bigger view...
    • Daviszone
« Reply #25 on: June 01, 2016, 12:14:57 pm »
Sluckey mentioned that you should remove the leftmost jack as it doesn't look standard and it may be part of the problem, in that picture, its still connected.  The other two look like standard switchcraft 12A type,  You may even want to try just one jack at a time, and then make sure that works, then add a second jack to see if that does a well, etc.  reduce variables, know what works and doesn't.
~Phil
Phil Davis
tUber Nerd =|D
« Reply #26 on: June 01, 2016, 01:12:00 pm »
I see that you have moved the brown and orange wires around on that oddball jack. Why? I want you to take the orange wire off that jack, tape it up, and don't reconnect it to anything until you have sound from the other jacks.
It's possible that you have other problems with the amp. Why do you suspect the original OT is bad? It's about time to post voltages for ALL tube pins. Also post the voltages on each of your filter caps.
Offline Oddvar
« Reply #27 on: June 01, 2016, 01:57:44 pm »
Hi Sluckey, I think you might be right, but the old OT made cracklingnoises when I touched the leads, and the sound came in and out.  I'll be checking on the voltage.
Offline Oddvar
« Reply #28 on: June 01, 2016, 03:45:51 pm »
Voltage:
V1 and 2: pin 1 and 6: 0.986 mv
V3: 295 v pin 1 and 6
V4 and V5: (6L6GC) pin 3 and 4: 475 v. pin 5: -5 an 51.9.
I'll do the rest also.
« Reply #29 on: June 01, 2016, 05:56:11 pm »
That will certainly make an amp have no sound.
pin 5: -5
That's not good either.
Offline labb
« Reply #30 on: June 01, 2016, 08:20:11 pm »
Pin 1 and 6 on V1 (if that is your first pre amp tube) should be about 150 VDC
Pin 1 and 6 on V2 (if that is your second pre amp tube) should be about 180 VDC
Pin 5 on the 6L6's should be about -48 VDC.
Offline Oddvar
« Reply #31 on: June 02, 2016, 01:26:57 am »
So what could the reason for lack of voltage be? :w2:
Offline Oddvar
« Reply #32 on: June 02, 2016, 02:23:46 am »
 :laugh:
Hi guys, thanks to you I found the problem, one of the leads underneath the board from the volt drop resistor to the 10k B+4 was loos, now it all sounds great...
Thanks.
    • Daviszone
« Reply #33 on: June 02, 2016, 09:15:40 am »
Good to hear, you may want to look it over with a fine toothed comb to look for any other solder issues etc
Phil
Phil Davis
tUber Nerd =|D
