July 31, 2026, 11:18:57 pm
Hoffman Amps Forum image Author Topic: Found a Traynor YGL-3 Mk III and need some advice  (Read 9882 times)
Offline smackoj
« on: June 05, 2016, 07:19:42 pm »
I found and bought this Traynor YGL-3 MkIII amp in Longmont, CO yesterday. I believe it dates to 1976. It works but has a lot of hum and the occasional snap, crackle and pop. The 'first look' visual inspection shows a mostly unmolested chassis for a SS rectifier, four EL34 output tube beast that must have been Traynor's competitor for the blackface Twin Reverb. The power cable has been chg'd to a 3 prong and the power filter caps have been replaced with the low cost Xicon variety. I don't really see many changes but there is a major change in the output parts. The orig. OT has been removed and replaced with what appears to be a Classictone 40-16823 tranny. Unfortunately that is a 2 output tube PP OT and this amp has four 6CA7 output tubes. Some 'tech' ran a short jumper wire between the pin 3 of the two sets of 2 output tubes. Then they used the normal output connection with a blue wire and a brown wire from the two sets of output tubes to the primary of the OT. Also, the two orig. speakers were replaced with a 16 ohm Peavey and a 8 ohm Fender (italy). That obviously does not seem like a good ohm application but they may have wanted to try and "match up" the 2 output tube OT with four power tubes and 2-12" speakers? I would like to have any/all suggestions for what OT I should consider purchasing for this amp? I am not a big fan of Merc Mag OT's mostly due to cost.
Thanks mucho amigos
 :icon_biggrin:
« Last Edit: June 05, 2016, 07:28:02 pm by smackoj »
Re: Found a Traynor YGL-3 Mk III and need some advice
« Reply #1 on: June 05, 2016, 08:21:38 pm »
I can't find any info on that OT. Are you sure about the number?
Offline smackoj
« Reply #2 on: June 06, 2016, 01:22:05 am »
there is no name badge on the OT. It is black all over with metal end bells and these numbers:
P-TF22899
40-16823
166-0249
« Reply #3 on: June 06, 2016, 09:19:47 am »
That OT is a replacement for a Fender Twin Reverb. It's rated for 100W, 2KΩ:4Ω. Should be a fine replacement in that Traynor amp.
« Reply #4 on: June 06, 2016, 11:54:04 am »
FWIW: Dan Torres suggests a power supply upgrade: "Inside Tube Amps", p247, ff.  KOC might have some ideas in his TUT series.
Offline smackoj
« Reply #5 on: June 06, 2016, 08:58:47 pm »
"replacement for Twin Reverb"  I thought a 4 output tube amp had 4 wires to connect to the four power tubes?  This tranny only has a blue and a brown wire from two sets of two power tubes. Is that the right primary hookup for a 4xEL34 tube output? again, I thought each power tube got it's own wire from tube to the OT? And I only see a green and black wire on the secondary side so I don't know where the other tap for 2 or 4 ohms would be? I haven't removed the OT so maybe someone cut wires off really short and I'm not seeing them?  I will look closer. thanks
I am having trouble with my home wifi so I may not get to read or respond on a tight schedule. sorry.
« Reply #6 on: June 06, 2016, 10:58:11 pm »
No. Why would you think that?
Yes. That's exactly what the schematic shows.
No.
That's exactly what the Traynor schematic shows. That amp was set up to run 2 8Ω speakers in parallel. 4Ω total. No provision for 2Ω or any other speaker impedance.
No. There were only 5 wires on the Traynor original. Red, blue, brown for primary, green, black for secondary. Exactly the same on the replacement. The replacement is an excellent choice for that amp.
I will look closer.
Take a look at the schematic. It's in Hoffman's schematic library. Link at bottom of this page.
« Reply #7 on: June 07, 2016, 07:58:29 am »
Here's some interesting mod info. Might be some of Torres recommendations .
http://studioboytimes.tumblr.com/post/145078185439/traynor-ygl-3-upgrades-mods?is_related_post=1
Offline Ugly Distortion
« Reply #8 on: June 07, 2016, 08:46:59 am »
Those Xicon caps are as good as anything else. Diligent of the tech to squeeze them into their original clamps and maybe chose caps that fit the ring - and that he didn't harvest the mustards.
« Last Edit: June 07, 2016, 08:54:55 am by Ugly Distortion »
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #9 on: June 07, 2016, 11:46:46 am »
It plays, right?  Track down the hum and sputter first and then think about upgrades/mods.
Offline smackoj
« Reply #10 on: June 07, 2016, 08:52:18 pm »
hi; sorry SL, I just always thought that 4 tube output had a separate wire to the primary for each tube. I never owned or worked with a 4 banger so I obviously thought wrong. I couldn't read the schemo because my internet went down. I will download a copy now while I have the chance. thanks as always for your help.
I probably won't do any mods. at least not at first. I want to get her running quiet and strong first and see if I like what it came with stock.  :icon_biggrin:
....and about those 'mustard caps' I never had those before either so I'm excited to hear the mojo workin'.
thanks to one and all.  smacko jack
Offline smackoj
« Reply #11 on: June 08, 2016, 05:37:51 pm »
post previous script. "why would you think that?" about the output tubes each having a wire to the OT. I remember now why I thought that Steve. The fact that the tranny had been replaced and instead of have two 8 ohm speakers in parallel making the customary 4 ohms, there is a 16 ohm and an 8 ohm set of speakers wired in series making an oddball load. So, I concluded that the tranny was wired in in odd fashion and the strange speaker hookup was there to adjust for the oddball tranny hookup. It seems as though someone just hacked together the 16 and 8 ohm speakers in series for some unknown reason but it led me astray on what I thought was going on.  Live and learn as folks like to say.
 :icon_biggrin:
« Reply #12 on: June 08, 2016, 08:04:42 pm »
I think the OT was replaced by a competent technician. The odd speaker configuration probably came later by a different person.
