September 15, 2026, 02:27:46 pm
Hoffman Amps Forum image Author Topic: Prince Royal schematic  (Read 8428 times)
Offline Blind Lemon
  • Do you smell something.....OH Crap! It's smokin'
« on: June 06, 2016, 07:49:35 pm »
Anybody have a schematic for TH Prince Royal. I have one on the bench and am thinking the problem is in the boost circuit. Very low output.
TIA
BL
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: Prince Royal schematic
« Reply #1 on: June 06, 2016, 10:43:46 pm »
I don't kno of them myself, and it seems there's only a 'king royale' in the schematics library: http://el34world.com/charts/Schematics/files/top_hat/tophat_kingroyale.pdf
But maybe the king is similar to the prince?  The schematic is obviously one someone did by hand...
Hope that helps anyway?
Phil Davis
tUber Nerd =|D
« Reply #2 on: June 06, 2016, 11:01:05 pm »
Let's see some pics Blind Baby. I always want to call you Blind Melon Chitlin' for some reason.   :icon_biggrin:
Offline Blind Lemon
« Reply #3 on: June 07, 2016, 10:58:42 am »
Steve how you doin? You missin the agency I bet. :laugh:
I'll send some pic's when I get home from work.  :BangHead:
BL
https://www.google.com/search?q=top+hat+prince+royale&client=safari&hl=en-us&biw=1024&bih=672&tbm=isch&source=lnms&sa=X&ved=0ahUKEwin9buDppbNAhVB_IMKHfEtCM8Q_AUICCgB&dpr=2
Just did a search for image. Third row 2nd over. It's a SE EL84 with an EF86 front end. Boost board on the left.
That will have to do until I get back to the house.
« Last Edit: June 07, 2016, 11:07:35 am by Blind Lemon »
    • Daviszone
« Reply #4 on: June 07, 2016, 11:39:36 am »
Sorry that image is so small that my bad eyes can't make much sense of it :(
If you can get some good high res ones that would be great.
~Phil
Phil Davis
tUber Nerd =|D
Offline Blind Lemon
« Reply #5 on: June 08, 2016, 08:58:01 am »
Sorry for the delay.
Offline Blind Lemon
« Reply #6 on: June 08, 2016, 09:00:14 am »
More:
Offline Blind Lemon
« Reply #7 on: June 08, 2016, 09:01:27 am »
again:
Offline Blind Lemon
« Reply #8 on: June 08, 2016, 09:08:38 am »
Last:
Offline SILVERGUN
« Reply #9 on: June 08, 2016, 09:55:41 am »
Do you always have low volume or just when you switch in the boost?
Offline Blind Lemon
« Reply #10 on: June 08, 2016, 10:21:35 am »
Low all the time. Got a schematic?
Offline SILVERGUN
« Reply #11 on: June 08, 2016, 10:23:42 am »
No...sorry
Looks like they tacked a boost pedal on the front end.
I'd bypass it and see if you still have low volume....it'll help you rule out the boost circuit.
Offline Blind Lemon
« Reply #12 on: June 08, 2016, 11:23:12 am »
thx
Offline Blind Lemon
« Reply #13 on: June 09, 2016, 04:00:57 pm »
Here's what I know. When I disconnection the power and input into the boost peddle the amp works. (Fine?) The plate of the EL84 is running at a lower V than the suppressor grid. (A=266 vs G3 =279) So it's running in triode. (?)
I hate peddles. Guess I'll pull it out and draw it up. The sand is a J201.
    • Daviszone
« Reply #14 on: June 09, 2016, 04:26:19 pm »
Well, I can't see the underside of that booster, but the likely candidates for problems would be one of those three electrolytics, the one radial and two axials.
Depending on how old they are, they could be dead/dying.  Otherwise the rest of the circuit should be pretty simple stuff and running at pretty low voltages.  If the pnp/npn went out, it wouldn't boost at all I'd think (Or I'm guessing that's whats there, but it could be a jfet etc?)
~Phil
Phil Davis
tUber Nerd =|D
Offline Blind Lemon
« Reply #15 on: June 09, 2016, 04:33:08 pm »
First pic above. Built in 2002 by Bobby. (?)
It make no noise with the boost on and with it off you can just hear it very faintly.
« Reply #16 on: June 09, 2016, 10:13:32 pm »
... The plate of the EL84 is running at a lower V than the suppressor grid. (A=266 vs G3 =279) So it's running in triode. (?) ...
Did you mean "G2" (screen grid)?
Your hand-drawn circuit shows G3 connected to the EL84 cathode (which is an internal connection). Pin 9 would be G2.
The drawn schematic also shows the screen at the opposite side of the OT as the EL84 plate; that equals pentode-mode. Triode-mode would be plate & G2 on the same side of the OT winding.
Since the plate & screen grid ultimately tie to the same filter cap (according to the drawn schematic), but the plate has the d.c. resistance of the OT in the way, it would be natural for the plate voltage to be lower than the screen voltage. Doesn't really matter to the tube in this case.
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #17 on: June 10, 2016, 07:13:43 pm »
From the symptoms and the photo's, I would say that the gate of the J201 jFET is connected to the input at all times.  The jFET may have failed with the gate shorted or nearly shorted.
With the switch on "Boost", what is the resistance across the input jack with a phone plug inserted?  Try reversing the DMM leads and see what resistance it reads like that.
Offline Blind Lemon
« Reply #18 on: June 12, 2016, 12:10:33 pm »
See if this looks right. Not sure what kind of diode that is.
HBP - You are correct, I was mistaken. G2 not G3.
« Last Edit: June 12, 2016, 12:14:31 pm by Blind Lemon »
Offline Blind Lemon
« Reply #19 on: June 12, 2016, 12:52:26 pm »
I had some 201's, so while I had the little board out I ut out the old one and soldered in a new one.
BINGO
