September 17, 2026, 04:12:05 pm
Hoffman Amps Forum image Author Topic: Is a 1629 tube usable as audio level meter ?  (Read 6085 times)
« on: June 11, 2016, 12:17:39 pm »
I tried a search but I find only schematics where the 1629 is used as a sintony indicator
Datasheet
http://www.mif.pg.gda.pl/homepages/frank/sheets/049/1/1629.pdf
I would like to know if it is usable as an audio level indicator and be happy if someone has a schematic or link to share
Re: Is a 1629 tube usable as audio level meter ?
« Reply #1 on: June 11, 2016, 02:08:22 pm »
Golly. Many-many-many tape recorders used Eye-tubes as recording level indicators.
Bring your audio up to ~~8V peak. Rig a rectifier to get a negative output.
Old basic use-sheet: http://www.mif.pg.gda.pl/homepages/frank/sheets/021/6/6E5.pdf
Italian: http://www.mif.pg.gda.pl/homepages/frank/sheets/084/6/6E5GT.pdf
« Reply #2 on: June 11, 2016, 02:22:17 pm »
Thanks PRR
can the signal be take at the secondary of the OT ?
Thanks for the 6E5 datasheet
is the 1629 usable following same directives of other magic eyes tubes (when used as audio level meters) ?
p.s.: Strange thing, I've found info about the use of the 1629 as amplifier ........... :huh:
« Last Edit: June 11, 2016, 02:28:34 pm by kagliostro »
« Reply #3 on: June 11, 2016, 02:28:34 pm »
Actually, in a tube guitar amp it may be easiest to take signal at the speaker jack.
Rectifier loading is a non-issue at such low impedance.
8V peak in 8 Ohms is only 4 Watts. Most amps exceed that. Bigger amps, put a pot before the rectifier.
« Reply #4 on: June 11, 2016, 02:31:22 pm »
Yet thanks
p.s.: Have you seen the p.s. I added to my previous post ? (  :huh:  )
