September 17, 2026, 05:02:21 pm
Hoffman Amps Forum image Author Topic: Adding series resistance to reduce output  (Read 8217 times)
g-man
  • Guest
« on: June 13, 2016, 04:37:58 pm »
Deleted
« Last Edit: August 06, 2024, 04:09:02 pm by g-man »
Re: Adding series resistance to reduce output
« Reply #1 on: June 13, 2016, 05:50:56 pm »
About half-way down this page is an explanation of how to determine the value of a series dropping resistor to attenuate a speaker.  Though it says it's for a tweeter, it's true for any speaker.
http://techtalk.parts-express.com/forum/tech-talk-forum/15515-series-resistor-for-tweeter-attenuation
You may wish to consider an L-pad attenuator for the louder speaker.  It's like a rheostat; is adjustable to taste like a pot; no math; and at any setting it preserves the ohm's rating of the speaker.
g-man
  • Guest
« Reply #2 on: June 13, 2016, 06:30:45 pm »
Deleted
« Last Edit: August 06, 2024, 04:08:30 pm by g-man »
« Reply #3 on: June 13, 2016, 09:55:49 pm »
A fixed resistance L-pad is fine, so long as you are correct about the dB drop you need.  And, yes, use 8 Ohm's for that one speaker being attenuated.
Offline drgonzonm
« Reply #4 on: June 19, 2016, 10:57:32 am »
When I read this post, I thought you wanted to reduce the output of the cabinet, not to balance the cabinet.   The simplest way I know to reduce a cabinet output, is to switch from from parallel to series, this will reduce the output, and therefore the volume.
I am curious at what frequency Weber is using to determine Z?  Is he using the nominal impedance?  Without further info, the Weber calculator is at best qualitative and not quantitative at all.
Are the speakers the same model and the same brand?  Maybe you can find typical frequency data for the speakers, so you can use the Z (which is frequency dependent)   To rubgoldberg this, and make it quantitative, there is quite a bit more work to do.
Maybe one of the gurus, will explain the weber L-pad e
« Reply #5 on: June 19, 2016, 06:15:07 pm »
g-man's post:  The only problem is that one speaker is a bit louder (more efficient) than the other. I'm wondering [how to] to balance the output without harming the speaker or amp.
The following is off-topic:
Yes, but it creates an impedance mismatch with the amp (unless there's a matching OT tap); though the impedance mismatch is probably tolerable.
Yes, that's shown on the Weber Calc website.  L-pad design assumes the nominal impedance of the speaker driver.  This is good enough to obtain the specified amount of attenutuion.
An L-pad is a voltage divider.  There are an infinite # of values for the series and shunt resisitors in a voltage divider, which will yield the desired voltage reduction.  The L-pad uses certain specific resistor values, which together with the nominal speaker load rating, preserve that load as "seen" by the amp.
« Last Edit: June 19, 2016, 06:17:21 pm by jjasilli »
Offline drgonzonm
« Reply #6 on: June 20, 2016, 11:19:28 am »
The title of this thread is "Adding series resistance to reduce output"  My solution does that.
I do not disagree with the fact that an impedance mismatch is taking place.  It won't hurt a 2 ohm or 4 ohm output to be hooked up to a 16 ohm nominal impedance.  however, the reverse is not true.   Misquoting association football "No harm no foul"
Thinking about the problem, Using the assumption, both speakers are the same model, same manufacturer, and same year, it could be dirty contacts/poor solder joint within the cabinet. You're not looking at a lot of difference in resistance at the connectors to get a detectable difference in speaker performance
« Reply #7 on: June 20, 2016, 11:44:46 am »
Good point, about which g-man's 1st post is vague.
@g-man: are these two speakers the same model???
g-man
  • Guest
« Reply #8 on: June 20, 2016, 05:19:57 pm »
Deleted
« Last Edit: August 06, 2024, 04:07:49 pm by g-man »
Offline drgonzonm
« Reply #9 on: June 20, 2016, 06:43:43 pm »
Jjasilli, you points are well taken.
See how assumptions have gotten me into trouble.
At, the best, what we are looking at qualitative solutions
