September 15, 2026, 06:51:56 am
Hoffman Amps Forum image Author Topic: In wich amp was used the Duette Ampeg Preamp ? (that uses a 6SJ7 as optional)  (Read 6958 times)
I've find this interesting preamp schematic (to me is interesting that there is a tone control that follows a pentode)
I would like to know more about this 6SJ7 optional pentode channel used on the Duette, someone has news about ?
Which is the schematic of the whole amp ?
« Last Edit: June 15, 2016, 01:13:23 am by kagliostro »
You have found a rare bird! Those amps were only around for a short time. They were built in a combo cabinet with a split chassis design. Preamp(s) up top, power amp/power supply down in the bottom of the cab. The power amps were a simple push/pull design. At least a couple different power amps were used. I see some reference to the power amps being called a '600' or '700' series amp, but I cannot find any schematic. The amps were said to have a clean sound well suited for jazz players. I found a few pics but no technical info other than the schematic you posted.
Ciao Steve
Yes, people refers to this amp as a good amp for Jazz
a bit of more info can be read here, unfortunately no schematic
http://www.ggjaguar.com/duette.htm
I think it was an interesting amp
p.s.: This 835 runs a pair of EL37 as the Duette
« Last Edit: June 15, 2016, 07:44:18 am by kagliostro »
I saw that page. There are also a couple pics elsewhere showing the back of the cab with split chassis.
Yes ... isn't cool ?  :grin:
Franco, you do find some interesting things!  surfing, I stumbled across an early reverberocket that uses a 6BK11 triple triode tube!! then I went looking for tube data, then......, then.....,then  I went to bed!
Thanks Steve
Hey Shooter something like the 6C10 tube on the Super Champ ?
http://el34world.com/charts/Schematics/files/fender/Fender_champ_super.pdf
about triple tubes in one bottle ........ give a look here  :smiley:
datasheet
http://www.mif.pg.gda.pl/homepages/frank/sheets/123/6/6AF11.pdf
on this link a project
http://solorb.com/elect/musiccirc/squirrelmonkey1/
! No longer available
Ciao
« Last Edit: June 15, 2016, 08:49:24 am by kagliostro »
the 6C10 tube
Yup, 6BK11 to 6C10, to schematics, crossed eyes.........It's a new day now,
I'm just gonna play outside :icon_biggrin: (for now)
Offline Paul1453
I recently got a Wollensak (3M) R-R with one of those triple tube compactrons in it.
I forgot which, maybe a 6C10.
Interesting you have EL37 output tubes.
I haven't run across any of those.
I'll have to check it's data sheet.    :dontknow:
I only find a data sheet for a Mullard EL37.
It seems like a very nice tube!
69 W PP at 400 V fixed bias with 2.5% distortion.
Probably rather rare, high quality, valuable tubes?
« Last Edit: June 15, 2016, 06:52:56 pm by Paul1453 »
EL37 wasn't anything so special. It was good for HIGH power, which was not often needed, and it wasn't cheap. It may have only been used in a dozen designs.
EL34 is very much the same idea, made cheaper, heavily promoted, and came about the time that high power amplifiers began to sell well.
