September 15, 2026, 01:17:59 am
Hoffman Amps Forum image Author Topic: Suitability of Marshall JCM 900 50w Dual Reverb 4500 for test build  (Read 7671 times)
Offline Zedman
Hello Folks, Im hoping some of you can help me out. Im a noob here so I will try and tread carefully.
Im looking to build a 50w Marshall style amp head so that I can learn more about tone mods and circuit design.
Unfortunately I suffer the tyranny of distance as Im in Australia and the cost of transporting heavy/ bulky items is considerable.
Although I realise that a Marshall JCM 900 50w Dual Reverb 4500 suffers a poor reputation which I agree with, I have the opportunity to get one at a decent price. The EL34 forums have some posts about gutting and converting these amps.
So my question is, are the PT and OT in these amps of sufficient quality to make as a good enough base for conversion?
A similar chassis in Aus costs about $300AUS on its own! Even if a rebuild costs a couple of hundred in parts, I may be better off than starting from scratch and importing the lot.
OK any help will be appreciated.
Cheers
Z
« Last Edit: June 18, 2016, 05:11:08 pm by Zedman »
Re: Suitability of Marshall 4550 for test build
« Reply #1 on: June 18, 2016, 07:45:00 am »
I can't find any info on Marshall 4550. Are you sure about that number?
« Reply #2 on: June 18, 2016, 08:40:43 am »
The only 4550 I know of is the  David Bray  4550, so I think the OP is talking about a 50 watt plexi.     http://www.davidbrayamps.com/vicjohnson.html
Did you mean Marshall 2550 Jubilee re-issue?
« Last Edit: June 18, 2016, 08:51:53 am by mresistor »
Offline Zedman
« Reply #3 on: June 18, 2016, 05:09:17 pm »
oops my bad that was a finger error.
Its a Marshall JCM 900 50W, model 4500. The Dual Reverb that is part solid state front end
cheers
Z
Re: Suitability of Marshall JCM 900 50w Dual Reverb 4500 for test build
« Reply #4 on: June 18, 2016, 06:02:38 pm »
yes
Offline Zedman
« Reply #5 on: June 18, 2016, 07:09:33 pm »
Thanks Mr sluckey!
Z
« Reply #6 on: June 18, 2016, 09:15:24 pm »
I gutted one yrs ago and turned it into sort of a Plexi 50w with a paralleled V1 tube.  Sounded great.
with respect, Tubenit
Offline Zedman
« Reply #7 on: June 18, 2016, 11:42:02 pm »
Thanks Mr tubenit, it was your posts that gave me the idea that this would be a good place to start.
Starting using an existing amp should save me a good deal of money. I did some research yesterday and everything is expensive here- even the wooden case for a Marshall style head is about $300AUS. Add in the chassis, PT, OT and hardware I can see that it will all add up too quickly.
Thanks for the help fellas, its much appreciated.
Z
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #8 on: June 20, 2016, 12:40:34 pm »
Have you thought about making your own chassis and cabinet?
Check out uncle doug's videos on youtube lots of valuable information there:
https://www.youtube.com/user/Stratosaurus1/videos
Constructing a Finger-Jointed Pine Amplifier Cabinet
https://www.youtube.com/watch?v=GTLfe9UViwE
Also check out on youtube how to bend aluminum plates to make the chassis.
https://soundcloud.com/ukiuki
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #9 on: June 20, 2016, 04:04:22 pm »
I've tried doing both chassis and cabinet, and have learned that although I'm pretty good at building amps, I'm not good at building chassis' and cabinets :)
They don't look too bad, but I didn't enjoy making them, and was fully sick of the process when I finished :)
But you should definitely give it a try once, there's a pretty significant sense of accomplishment on completing it.
~Phil
Phil Davis
tUber Nerd =|D
Offline Zedman
« Reply #10 on: June 23, 2016, 04:04:55 am »
thanks Fellas, one day I may give this a go but these days I am really considering the value of my time.
If I can earn more money, than purchase cost, by doing repairs in the same time it would take to make something its a no brainer.
Z
