September 14, 2026, 11:21:22 pm
Hoffman Amps Forum image Author Topic: Does higher elevation equal running hotter?  (Read 4501 times)
Offline super&plexi
  • Love 2 gig for bread...Love 2 play/jam for free
« on: June 20, 2016, 08:54:09 pm »
Does anyone know of or have experience with an amp running hotter at a higher elevation. I'm usually around sea level but presently at around 6500 feet and noticed my rectifier tube gz34 glowing bright yellow on the plates and I don't think it usually does, at least that much. After playing about an hour the amp seemed abnormally hot, although the room temperature was a little warm to begin with. Wall AC was 121 and it's usually 119 -122. I haven't played the amp a lot in the past couple years, and do usually play it through a variac at about a hundred and ten, but definitely have played  it without the variac in that time and don't remember it being this hot.
keep on with those scales and that fish is gonna die, if it don't bite you first!
never fried a tranny ..till I built a dim bulb tester. UPDATE-haven't fried anything since learning how to properly build & use one...thanks Uncle Doug, & el34 World
Re: Does higher elevation equal running hotter?
« Reply #1 on: June 20, 2016, 11:07:12 pm »
Bright yellow on the plates is very wrong.
Thin air does mean less cooling, but not so you would notice (any altitude you can function at).
