August 29, 2026, 02:05:02 pm
Hoffman Amps Forum image Author Topic: OT fibre washers - where do they go?  (Read 4996 times)
Offline DLPublic
  • I like to play The Shadows stuff
    • Dave Lewis plays The Shadows ~ CD
« on: June 30, 2016, 04:55:05 am »
My output transformer has two fibre washers along with one flat and one shake proof washer per fixing bolt.
I presume one of the fibre washers is placed between the bolt head and the metal cover at the top of the OT, but where does the other one go?
Dave
« Last Edit: June 30, 2016, 11:04:45 am by DLPublic »
DIY handmade Hank Marvin replica stratocaster, Marshall MG15FX amp (DIY AC15 on the way!). Zoom G2.1nu+EFTP + DIY FXs.  Roland EXR-7s keyboard. Acoustic guitars, mandolin, banjos, penny whistles, bhodran, etc. Self built PC (X79 m/b, i7-3820 o/c 4.2GHz, 16GB RAM, GTX770 GPU), Sonar X3 DAW.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: OT fibre washers - where do they go?
« Reply #1 on: June 30, 2016, 08:33:57 am »
Hi there!
Lots of installation instructions in this link: http://el34world.com/Hoffman/instructions.htm
https://soundcloud.com/ukiuki
Offline DLPublic
« Reply #2 on: June 30, 2016, 11:03:04 am »
Uki,  have already read (and re-read) that info but it does not answer my question.  Also have tried a search for fibre (and fiber) washers and output transformer which proved fruitless.  I have also emailed the supplier of the transformer, but as yet no reply.   :help:
Dave
« Reply #3 on: June 30, 2016, 11:10:33 am »
I'm looking at an OT setting on my desk, it has 4 bolts holding the end-bells on, each is;
fiber washer, plastic sleeve on screw *head* side.  the other is plastic sleeve, fiber washer, metal washer, nut.
not sure if that helps
« Reply #4 on: June 30, 2016, 11:17:20 am »
Dave
Is your OT not bolted together?
Normally you would put one fiber under the bolt head, shove the bolt thru the OT, then place a fiber, followed by a flat, followed by a star, followed by a nut on the other end of the bolt.
Offline DLPublic
« Reply #5 on: July 01, 2016, 11:49:49 am »
Thanks all for your comments.
I have had a response back from the OT supplier and he agrees with Sluckey.  It is supposed to prevent the bolt making a shorted turn through the stack but that also requires the bolts to be insulated from the edges of the holes in the chassis, which mine are not!
Hope that is not an issue.
« Reply #6 on: July 03, 2016, 04:34:32 pm »
That's goofy
Who ships transformers with the insulation washers not installed?
The manufacture installs them when they assemble them
Offline DLPublic
« Reply #7 on: July 04, 2016, 12:03:56 am »
That's goofy
They were installed, that is how I knew where the top one went.   However was not sure whether the bottom one should be above the chassis, I.e. directly underneath the OT, or below.  Turns out it is below.
